what tool to get cover off steering column? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 04-10-2012, 01:45 PM Thread Starter
drooling piston's Avatar
I want to get the plastic cover off the top & bottom of the sterring column on my 97 with auto. I ground down the outside diameter of a 3/16 and 1/4in nut driver so they would fit in the hole but neither will turn the bolts. Local tool shops dont seem to carry anything smaller than a 5mm nut driver.
what have you used to get those bolts out?
thanks for your help
1997 ext cab 2500, 2WD, SLT, 5 gauges, #10 fuel plate, afc tuned, head studs, 60# valve springs, 5in exhaust. DDP 75HP injectors. timing 18*, 4k GSK, HE351VGT, 13spd road ranger trany, Home made twin ram style intake, sump drain with FASS fuel system
drooling piston is offline
post #2 of 7 (permalink) Old 04-10-2012, 05:36 PM
whatsmokin's Avatar
I'm not sure about a 97 but on my 95 it was just one T25 torx through the bottom then it was just held on by clips in the plastic.
Sent from my Autoguide iPod touch app
94,95,98 2500 quad cab long bed 4x4 132k miles, 4K GSK, Plateless, Hamilton 188-220 cam, boost elbow, Isspro boost,pyro & tranny temp gauges, DDP .024 DVs, 5in straight pipe
, 60# valve springs, ARP head & main studs, Diesel Auto Power 5x.014s, 64/71/14
whatsmokin is offline
post #3 of 7 (permalink) Old 04-10-2012, 08:18 PM
Ignition Switch Replacement
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
The Following User Says Thank You to illflem For This Useful Post:
drooling piston (04-11-2012)
post #4 of 7 (permalink) Old 04-11-2012, 12:39 AM Thread Starter
I will have to get a flashlight and a pick to see if there is a hole in the center of those bolts that are up in the long skinny plastic tube.
when I first looked i didn't see the star shaped hole that would have me looking for my torks drivers.
post #5 of 7 (permalink) Old 04-11-2012, 09:09 AM
12v power !!!!'s Avatar
there are 4 torx holding it on there, one in the center towards the steering wheel(easiest to see), one on the left and right of that one (they are up in these little holes youll see there), the last one is on the right side of the column just to the steering wheel side of the gear shift lever (its up in a hole also), they all go in from the bottom and the 2 pieces just snap together, hope this helps
1997 dodge 2500 12 valve 4x4, modded and Sold!
2001 Dodge 2500 24 valve 4x4 with BIG plans
12v power !!!! is offline
post #6 of 7 (permalink) Old 04-11-2012, 11:22 AM
You have to use a screwdriver type torx driver, the type with a bit and holder won't fit up though the hole.
Pretty sure it's a T-20
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #7 of 7 (permalink) Old 04-11-2012, 03:37 PM Thread Starter
Ok you guys were right. after putting on the drug store cheeter glasses and giving those holes a shot of compressed air to blow out the dust, I did see the star shaped hole in those bolt heads.
A T-15 driver got them right out.
I am grateful for your advise and feel silly at the same time.
thanks!
