Need help. Will doors from a 2001 ram single cab 1500 fit my 97 2500 club cab? My back doors do not open.... So i think its a club cab, correct me if i am wrong.
Thanks
97 12v auto- Tuned pump, Afc FF, No plate, Banks big head wastegate, 4" tb exhaust, billet single disk converter
Look at the bottom of the door on the back. As long as both doors are square or rounded and the same generation they will interchange.
1997 3500 club cab Automatic 3.54 gears towing and camper package. Still stock with 116k on it so far. 4" dynomax stainless exhaust, 4kgsk, and pacbrake exhaust brake waiting for installation. Still need ideas for improvements for hauling 15k fifth wheel.
check the bottom of the doors. On single cabs and club cabs: the door is rounded at the bottom rearward side. On the newer 4door(quad cab trucks the doors are more squared off) just check before you buy them
There the same gen. So if there both rounded at the bottoms they will fit? My door bottoms are rounded.. And also does anyone know if all the power window and other door options will be interchangable as far as wirring and such.?
The only difference of note is that bottom. It can be cut down or welded and added to if no other options exist. Since you have the same kind of doors they will just bolt on.
I am not sure about the wiring. If worse comes to worse you can just change it out. It would just take some time. I once put a power door in a non-power cab. It just took some time to put the parts from the old door in.
No the 2nd gen are not longer or shorter. They are same length just different shapes at the lower rear corner... THe only thing that could be a little different is the wiring harness that plugs into each other. Worst case, cut them and reconnect the other harness. It is not hard, just takes a little time
Okay thanks guys. The guy said the bottoms of his doors are rounded and so are mine. So im crossing my fingers that they will sit flush in the door frame. Only one way to find out....
