Should I Buy???? ADVICE NEEDED - Dodge Cummins Diesel Forum
Old 03-28-2012, 08:05 PM   #1 (permalink)
Hey hows it goin guys. My names Mike and Im new to the forum. Im 16 and currently am in the market for my first truck, and after tons of research i decided that a 12 valve 5 speed is the way to go because they r simply proven bulletproof drivetrains. I would be using the truck for plowing, Lawn maintenance on the side of my job for a masonry company in the summer, and also hauling things for dump runs if people need it. Now, I found a 94 5 speed with 290k on it, no rust (the guy redid parts that were rusted), good tires and breaks, southbend clutch, new ball joints and dual steering stabilizers, 4 inch mbrp exhaust that comes with it but currently has a 6 inch stack which i would be taking off immediately, 3 owners 2 of them younger guys who used it as daily drivers and a project truck, never a work truck or plowed with or anything according to the guy, and says the only flaws are a ripped drivers seat and a dew dents that could be popped out in the bed. Paints ugly but me and my uncle r gona paint it anyway. Now, my concern is the truck itself because I know the drivetrain will be good for a while longer. I know the 2nd gen dodges have weak front ends and whatnot, but seeing as it really wasnt a work truck I don't know how how the truck itself will hold up and how much maintenance will be on a truck like this once its put to work with that many miles on it. If anyone can help me get an idea of what it will cost and what I should watch out for that would be awesome, and what your opinions are on if its worth the price or not to buy a truck with that kind of mileage for work. Let me know as I am going to see it Saturday. Thanks a lot guys,
Mike
Mzarlenga is offline   Reply With Quote
Old 03-28-2012, 08:32 PM   #2 (permalink)
Well first off, it's pretty hard to tell if it's worth the price when you don't actually say the price in your post.
It could be a great truck or it could be a pile really, do some reading and you'll find everything you asked, and more.
I'll get you started but reAlly just read, I'm pretty sure there has been at least a dozen of these threads in the last couple weeks.
Looking to buy a 12 valve? Or recently bought one? Read this.
1998 R2500~8"taller,37"tires,S&B intake,Studs,Boost elbow,Built trans,afc tuning,PO installed injectors..?
Currently working to fix PO mistakes then...mod time
Jacked98-12valve is offline   Reply With Quote
Old 03-28-2012, 08:34 PM   #3 (permalink)
The engine will probably be good for a long time. Check it for blowby.
The transmission can lose 5th gear. The shaft is to short and the nut holding fifth gear on can fall off. No damage normally happens but it is annoying. A new shaft is the cure. With a lot of miles the synchronizer rings can wear out. People refer to that as feeling like it is "scratching" when shifting gears.
With that many miles you could be looking at replacing everything in the brake system. You could also be looking at a truck someone else already replaced the brakes.
Front end parts are suspect anytime a vehicle hits the 100k mark. From then on it is always something to think about. If the front end parts are not bad now they will be in time (the same as any vehicle). The steering box can go bad.
Obviously things like the starter, alternator, water pump, and other normal wear items may need work.
Look for oil leaks. When you come back tell us how many you found. Cummins like to mark their territory with black spots. That is usually minor but annoying. Does the truck smoke much when it is started cold? In cold weather smoke will happen. In warm weather very little or no smoke will happen for only a short time.
Do not let my list above scare you. I would look for the same things on a vehicle with 125k on it.
After you get the truck home fix the KDP immediately. That can be expensive to repair if it lets go.
Read the thread in the link below. It explains a lot about these trucks.
Beginners Thread - Read First!
1997 3500 club cab Automatic 3.54 gears towing and camper package. Still stock with 116k on it so far. 4" dynomax stainless exhaust, 4kgsk, and pacbrake exhaust brake waiting for installation. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline   Reply With Quote
Old 03-28-2012, 08:41 PM   #4 (permalink)
Thanks guys and sorry i thought i put the price in it the guy wants 3500
Old 03-28-2012, 09:00 PM   #5 (permalink)
Well for 3500 bucks id buy it for sure if it has everything you listed previously, I'd say it's a steal
Old 03-28-2012, 10:35 PM   #6 (permalink)
The 4x4 axle ends from dodge are a weak point. There is a thread on here talking about using the pieces on the end of the front axle from a ford (I think). That puts a better system on the truck that eliminates a problem area. At the price you mentioned unless it has serious problems it is not overpriced at all.
