dana 70 posi clutch's question - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 01-15-2012, 09:52 PM Thread Starter
alextsi66's Avatar
Alright so the posi is out on my truck and the 1 tire fire things a little annoying. Was the dana 70's also not stacked right or is it just the d80? also will i have to mess with the backlash if i replace the clutches?
alextsi66 is offline
post #2 of 22 (permalink) Old 02-01-2012, 02:19 PM
'89dodge's Avatar
i really cant help but i am in the same boat with you the one tire peel gets me stuck quick, i don't think mine has posi
where did you look to find out if yours was?
2016 Chevy 1500 LT Z71 ccsb all stock 5.3 6speed 3.42.
2011 ram 1500 SLT 2wd she gone, not missed.
'89dodge is offline
post #3 of 22 (permalink) Old 02-02-2012, 09:44 PM
TStalnaker's Avatar
Look on the underside of your hood. You should have a sticker that tells you what your axles are, transmission etc.
2016 4500 Crew Cab, 4x4, Aisin, 4.10
2011 Ram 4500 Reg. Cab, 4x4, G56, 4.10
TStalnaker is offline
post #4 of 22 (permalink) Old 02-03-2012, 12:41 PM
The clutches are not stacked right. Also, they do wear out over time. You can stack them to make the posi really grab hard. No need to mess with the backlash. DON'T forget to add the friction modifier to the oil when you put everything back.
96 reg cab, 5sp long bed 4x4: 4GSK, pump and AFC altered, AFE filter, gasket matched and ported exhaust manifold, Fluidamper, 4" exhaust, gauges, 5th gear upgrade, KDP KO'ed, Hamilton cam, Southbend Con OFE, Bosch injectors, Dynatrac axles and hubs (don't go there, they don't stand by their product), airplane landing lights, Dana Powerlok's front & rear, front truss, F&R skid plates, runs on WVO.
Baja is offline
post #5 of 22 (permalink) Old 02-03-2012, 01:45 PM
'89dodge's Avatar
[QUOTE=Baja;4820248]. You can stack them to make the posi really grab hard. No need to mess with the backlash. QUOTE] i know this is a newbie question but how you stack it and wouldn't be hard going around a turn
and what is this back lash? again i am sorry for stupid questions just trying to learn since high school doesn't teach this stuff
'89dodge is offline
post #6 of 22 (permalink) Old 02-03-2012, 03:32 PM
'89dodge's Avatar
it says axle splicer 70
rear axle gear 3.55
email from dodge says dres dana m70/ 267mm rear axle what ever that means
'89dodge is offline
post #7 of 22 (permalink) Old 02-05-2012, 10:47 PM
95dually3500's Avatar
If it doesnt say limited slip on the sticker than its an open rear, mine said limited slip
96 2500 Reg Cab 4x4 - AFE Stage 2 Intake, Pusher intake 4k GSK,ground plate, pump tuned,fass 150 , Autometer-Gauges,Built auto w/Goerand Tripple,Disc
ED BIllet 66/68/.8 & 5x14's SDX Comp DV's 17.5* timing,
95dually3500 is offline
post #8 of 22 (permalink) Old 02-05-2012, 11:44 PM
'89dodge's Avatar
open rear=one tire spins
limited slip=both tires spins
correct me if i am wrong
thanks
'89dodge is offline
post #9 of 22 (permalink) Old 02-05-2012, 11:46 PM
country_hick's Avatar
Stacking the posi clutches refers to how they are installed. Some in one position and some in a different position.
Backlash is a measurement of how the gears line up.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
The Following User Says Thank You to country_hick For This Useful Post:
'89dodge (02-06-2012)
post #10 of 22 (permalink) Old 02-06-2012, 04:24 PM
'89dodge's Avatar
thanks for helping me figure that out what would be cheaper a swap? or just buying one for my truck (rear end) so i can add to list of long term items
'89dodge is offline
post #11 of 22 (permalink) Old 02-06-2012, 07:15 PM
No need to swap anything. Buy a clutch pack(s) from E-Bay and install them or have a shop install them. You may need two packs, my D-80 needed two. Even if you buy another rear end, you still have to check out the interior and it could easily have other issues.
Baja is offline
post #12 of 22 (permalink) Old 02-06-2012, 07:59 PM
make sure your truck had the limited slip before buying clutches, if your unsure call the dealer with your vin and they can tell you everything it had from the factory
