found water under floormat drivers side? - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 10-31-2011, 09:50 PM Thread Starter
96 dodge cummins 307k..I've found that under the mat on the drivers side is soaked? the factory installed insulation is soaked under the floor mat. any ideas? truck never has been hot
cgraves5653 is offline
post #2 of 25 (permalink) Old 11-01-2011, 01:18 AM
my truck did the same after driving in some hard rain for a day (700+ miles), not sure the root cause yet, thinking a leak under the cowl.
'92 Dodge Ram 250 Cummins ~parted and junked...
'04 Ram 3500 quad cab 4x4 auto long bed ~gone
'96 Ram 2500 cummins ext cab 2x4 long bed
turbo-max is offline
post #3 of 25 (permalink) Old 11-01-2011, 11:10 AM
TB1
Usually it's the third brake light seal that is leaking, The water will then run down the drip rail inside the cab and pool on the driver side floorboard.
1996 extended cab manning motor sports 63/68/14 , PDD budget builder 5x.014 injectors,.024 delivery valves, 4gsk, AFC mods, Mack rack plug,timing @ 17*Head studs Isspro gauges and AFC Live. PDD turbo tuner
TB1 is offline
post #4 of 25 (permalink) Old 11-01-2011, 08:22 PM Thread Starter
thanks turbo, I'll keep ya posted as to what I find..
post #5 of 25 (permalink) Old 11-01-2011, 08:26 PM Thread Starter
3rd brake light seal? I'm kinda lost on that. can you give me a bit more TB? Thanks again for the help ps - I vac'ed all the water out and dried out the mat, nothing else yet however ive not driven in any rain yet either..
post #6 of 25 (permalink) Old 11-02-2011, 12:16 PM
TB1
On the back of the cab the third brake light has a foam seal that is prone to drying out and cracking allowing water to leak in to the cab. I believe it was a dealer only part but wasn't that much $ seemed to have solved my problem
TB1 is offline
post #7 of 25 (permalink) Old 11-02-2011, 01:56 PM
good to know, i will check mine, thanks!
post #8 of 25 (permalink) Old 11-02-2011, 01:58 PM
ROLLIN SMOKE DIESEL
Broke Down's Avatar
iTrader Score: 13 reviews
my cab was cracked in 3 spots on the top back, my rear window was improperly installed from the factory and had gaps i could see through, and my heater core was leaking. does the water feel sticky and smell sweet? or does it have a water musk smell? the 3rd brake lights do have issues as well.
Duke- 2004.5 2WD SSR Tuned
Feel free to email me for quotes:
Monday-Friday 8am-5pm CST, online ordering 24/7
Broke Down is offline
post #9 of 25 (permalink) Old 11-02-2011, 06:35 PM Thread Starter
well im not real sure at this point what it is. I dont think its antifreeze. seems to be musky water. core has not ever shown any signs of leaking
Thanks, Charlie.. 96 dodge cummins stock-308k
post #10 of 25 (permalink) Old 11-02-2011, 06:52 PM
Hide your cats!
mstoaks's Avatar
Is it the rear passenger or front floor mat? This will make a difference. Yes the rear light can be leaky to that extent. You should have a fan or a heater of some sort blowing on the carpet to help prevent rust. The longer it sits with water the more probe to rust damage it will be.
2005 white auto, thanks to stoakenstine creations, 23 Diesel,smarty so6 Ats 5-star, 5" TBE to 6" stack, bhaf, GDP air boss, full triple pod, gdp 2 mic. edge ez 547hp 1078ft.lbs
mstoaks is offline
post #11 of 25 (permalink) Old 11-02-2011, 08:44 PM
TB1
Mine was the front driver side and I do have an extended cab... it ran along the drip rail inside the cab to the driver side front as it's the lowest point in the cab. Also from past experience when the heater core goes the passenger side floor will get wet
TB1 is offline
post #12 of 25 (permalink) Old 11-03-2011, 09:57 PM
It is your ac condensation dripping back into your cab, all disgrace do this there a seal that drys out. What you do is cut a 6" piece of garden hose and put it on the end of the ac drain that is located on the fire wall in the inside of the engine bay
Dodge 01 6spd HO, Gauges, fass 150, 4" exhaust, edge ez, boost elbow sold sold.
97 12v 3500 100hp sticks timming 17* running WMO
New truck 2010 4x4 long bed efi dave Mathews
Dodgejs is offline
