fuel tank diagram - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 10-28-2011, 03:35 PM Thread Starter
fuel tank diagram
Anyone have a diagram of the fuel tank, I had some work done on the bed of the truck now I see a small line, 1/4", looks like a vacuum line, just hanging there by the rear wheel. It has a plastic fitting on the end like another line plugs into it. If it's no big deal I'm just going to fix it myself. Any help would be appreciated.
Kevin
96 3500 Auto 2WD 4:10 gears, #10 plate, Goerand converter
9612v is offline
post #2 of 14 (permalink) Old 10-28-2011, 04:29 PM
cjensen91910's Avatar
Do yourself a favor and get a service manual. Here is a link for the CD from Geno's. It will pay off, big time, over a period of time.
1996 DODGE RAM FACTORY SERVICE CD-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
95 Auto, billet TC and modded valve plate, BHAF, Aux lift pump, three position lockup switch, full gauges, #5 plate, no muffler and CAT is gutless. Timed at 15.5, full EGR brake package.
cjensen91910 is offline
post #3 of 14 (permalink) Old 10-28-2011, 05:46 PM
9412valve4x4's Avatar
Mines just hanging out back there as well pretty sure its just a breather off the fuel tank
94 12valve auto gauges(boost, egt, trans, and fuel press.), 5" exhaust, 370 injectors, custom delivery valves, Gutted AFC, 2095plug, Tork TEK OFV, No Fuel Plate, Airdog 200, fuel sump, 4kGSK, and 60lb springs
9412valve4x4 is offline
post #4 of 14 (permalink) Old 10-30-2011, 12:09 PM
bmoeller's Avatar
Just a breather.
'93 W350 CC 5spd 500k miles.
'82 W350 crewcab dually, CTD, 6spd, 4wd
SOLD '92 W250 '97 3500, '99 3500
bmoeller is offline
post #5 of 14 (permalink) Old 10-30-2011, 12:25 PM Thread Starter
I'm going to get a chance today to look at it, maybe lift the bed up if its easy enough.
Kevin
9612v is offline
post #6 of 14 (permalink) Old 10-31-2011, 10:53 PM Thread Starter
I can't tell where it goes, have to keep looking I guess.
Kevin
9612v is offline
post #7 of 14 (permalink) Old 11-01-2011, 03:09 PM
Most times the vent is just cable tied to the big fill up hose.
No need to take off the bed for it.
In fact stock they don't come with a vent hose, just a barbed stub on top of the tank module.
Someone added the vent hose you have later.
Good idea if you're in a lot of mud.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #8 of 14 (permalink) Old 11-01-2011, 04:13 PM Thread Starter
The line I'm talking about starts on top of the tank, (tank module) the length looks as if it would go to the filler neck somewhere but there isn't a fitting or another hose to plug into. This line in question is what came with the truck as I'm the original owner, no one else has touched this truck. If the manual has a diagram I'll just buy the manual, now it's just bugging the out of me where it's suppose to go.
Kevin
9612v is offline
post #9 of 14 (permalink) Old 11-01-2011, 04:33 PM Thread Starter
I just ordered the manual, hopefully it will have a diagram or a clue to where the line goes. It will come in handy anyways. I wanted to buy the manual when I bought the truck, but it's one of those things where nothing needed fixing where I needed the manual.
Kevin
9612v is offline
post #10 of 14 (permalink) Old 11-01-2011, 08:50 PM
Someone added the hose, they didn't come with one. Perhaps the dealer?
You won't find it in the service manual.
In fact the trucks were new they were delivered to the dealer with the barbed fitting on the module capped off. Dealer was supposed to remove the cap.
Some dealers spaced out removing the cap, people had problems even going as far as collapsing the tank.
My bet is the dealer added the hose when they removed the cap.
The hose doesn't connect to anything on one end, just need to get the end up where it won't be in water and grime.
Like I said, most people just cable tie them to the large fill hose.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #11 of 14 (permalink) Old 11-01-2011, 08:51 PM
In fact when the trucks were new they were delivered to the dealer with the barbed fitting on the module capped off. Dealer was supposed to remove the cap.
Some dealers spaced out removing the red cap, people had problems even going as far as collapsing the tank.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #12 of 14 (permalink) Old 11-01-2011, 09:19 PM Thread Starter
This is from the front of the tank.
Top left hose is the one in question.
Top left again.
This is the hose with the end on it.
I don't know when the dealer would have put a hose on it, unless they did it before I bought it from them. Like I said I'm the original owner and it's only had the recalls done on it. I wonder if it has something to do with it being a California truck?
Kevin
9612v is offline
