No tach and no charge. - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 01-05-2008, 06:22 PM Thread Starter
Hi everyone, I am new to this forum and the diesel world. My son has a 94 dodge 2500 5.9 turbo diesel, auto trans he just bought. The tach is not working and will not charge the battery. My son is in auto tech shop at high school. The shop teacher jumped the relay to make it charge, thats all he had time for. The last owner said he replaced the computer. I was looking through the forum and found it could be the engine speed sensor, the sensor that is above the harmonic balancer. I called the dealers and they all want to call it the crank sensor, I do not think that is what it is called by what I have read on this forum. Any help you people can give me will be great.
Thanks, Gary
glegee is offline
post #2 of 12 (permalink) Old 01-05-2008, 07:15 PM
first off the last owner must have been kinda special 94-98 cummins have no computers on them. I had them same problem with the tach and on way to my work (mechanic) and then it started workin.
95 12v 2wd, reg cab, long bed.
94 12v 2wd, reg cab, long bed.
a3ftgiant is offline
post #3 of 12 (permalink) Old 01-05-2008, 07:25 PM
Gone Fishing!!
pro99's Avatar
They do have an computer on the 94 to 98's its called the pcm. More than likely the crank shaft sensor at the harmonic damper. Check your wiring from the sensor to pcm because if the pcm does not see an rpm it will not charge.
pro99 is offline
post #4 of 12 (permalink) Old 01-05-2008, 07:59 PM
Banned
I was going to say the Crank shaft sencor sounds like the right thing. and thanks for correcting the computer thing:thumbsupgood things for me to know later on...
GETERDID is offline
post #5 of 12 (permalink) Old 01-05-2008, 10:59 PM Thread Starter
So it is called the crank sensor. does anyone have the corrrect part number for it? When I go on to the NAPA web site it comes up with a part that does not look like what is on the truck now.
How would I test it to confirm it is bad? The truck still runs OK, just no tach or charging.
Thanks for all the quick replies.
Gary
glegee is offline
post #6 of 12 (permalink) Old 01-05-2008, 11:08 PM
That's def. what the problem is. I had the same problem. All i did was clean the contacts and put some die electric grease on it, and it worked like a charm. The trucks have issues if any kind of dirt or oil get on the contacts of any of the wires. Try that, also follow the wires down the wire loom back to make sure the wires havent been accidently cut. I purchased one of those manuals from auto zone, and it gave a step by step on how to replace it.
95' 2500 4x4
4 inch straight piped, BHAF, 3k gs kit
shorte_33 is offline
post #7 of 12 (permalink) Old 01-05-2008, 11:51 PM
gstanfield's Avatar
I have a very similiar issue except mine does not have any of the dash lights working (check engine, wait to start, etc) I'm pretty sure in my case it is hte PCM gone bad, but I hate ot buy it until I know for sure. Anyone know of a good method to be sure which part is bad??
Thanks,
George
1997 2500 ext cab long bed 4x4 Boost control elbow, BHAF, KDP tabbed, 3k gsk kit, dodgezilla hybrid turbo, Z-series gauges, 47RE built w/valve body & converter, #100 plate.
gstanfield is offline
post #8 of 12 (permalink) Old 01-06-2008, 11:44 PM
No. It's called the engine speed sensor or ESS.
Crank Position Sensor is not used on 12 valves, just the 24s.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #9 of 12 (permalink) Old 01-08-2008, 12:44 PM Thread Starter
FYI for everyone, I did some searching and I found MOPAR calls it the engine speed sensor, part #04746691. NAPA auto parts sells it and calls it a vehicle speed sensor, item# ECHVSS106. They are one in the same part but called two different names. I know NAPA calls it the wrong name just to confuse the crap out you. 10 bucks cheaper at NAPA. I am going to install it tonight to see if that fixes the tach and charge issues.
Gary
glegee is offline
post #10 of 12 (permalink) Old 01-08-2008, 06:18 PM
Are sure Napa is selling you the right part?
I think they aren't.
There is what is called a Vehicle speed sensor by Mopar but it goes on the tranny or transfer case to measure vehicle speed not engine rpm.
It wouldn't be that bad for Napa to misname a part but to call it the name of another part would be a major blow it.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #11 of 12 (permalink) Old 01-08-2008, 07:58 PM Thread Starter
If you go to the web site and put in that part number you will see it is the right one. Look in my truck pics link, I have a picture of it.
I changed the sensor and the tach and charge circuit works now.
Now on to all the fluid leaks
Thanks for all the help!!!
Gary
glegee is offline
post #12 of 12 (permalink) Old 01-08-2008, 11:28 PM
Gone Fishing!!
pro99's Avatar
Good job glad we could help:thumbsup
pro99 is offline
