Water leak in cab!! - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 03-08-2011, 04:34 PM Thread Starter
ajgroos's Avatar
Exclamation Water leak in cab!!
on my passenger side whenever it rains it makes a nice puddle of water under the floor mat. I cant figure out were it is coming from and a water hose gets me no results. Also it doest seem very wet up near the firewall carpet just in the middle and to the door. Anyone have this problem? im at a loss here, any info is appreciated.
1995 2500 4x4 long bed slt auto 370k. afe air intake, straight pipe, #100 plate, Glowshift triple pillar w/fp, pyro, boost, tc lock switch. Much more coming soon
2007 3500 4x4, 6 spd, quad cab, lb, mostly stock... for now
ajgroos is offline
post #2 of 18 (permalink) Old 03-08-2011, 04:47 PM
WhiskeyRider's Avatar
Sometimes the window seal on the door will leak over time or will get pushed up a bit from the door. From there the rain goes down into the door shell and through the drain holes in the bottom and leaves a puddle on your floor mat. Could be your door seal too.
'96 2500 RCLB, 47RE, 241HD, BHAF, Tuned AFC, #8 Plate, KDP'ed, MBRP T-B 4"-5" tip, Silencer Ring Gone, Skull Valve Stem Caps. In the works: 5" Lift w/6" coils. Dually Convert. Highway Products flatbed.
WhiskeyRider is offline
post #3 of 18 (permalink) Old 03-08-2011, 05:01 PM Thread Starter
ajgroos's Avatar
thanks for the advise. From what i can tell it is not coming from the door seal or holes at the bottom of the door. leaking windshield seal? i dunno.
ajgroos is offline
post #4 of 18 (permalink) Old 03-08-2011, 07:57 PM
Could be your third break light seal too
post #5 of 18 (permalink) Old 03-08-2011, 08:10 PM
same problem here, havent looked to see where its coming from though
94 airraid intake, stock straight exhaust, home made #100 plate slid all the way foward and the typical afc mods, SDX 5x12 injectors, KDP done, NV4500, 4x4, 188k
makohon is offline
post #6 of 18 (permalink) Old 03-08-2011, 08:18 PM
TYONEON's Avatar
Rear window drain holes get pluged and leak, third brake light, door fills with water and everytime you close it water gets by the seal, windsheild, vent cowel seam sealer missing, a/c overflow, heater core. All can cause the lake.
1994 SLT Laramie RCLB Auto 4X4 SOLD!
2015 2500 SLT CCLB 5.7 Hemi 4x4
TYONEON is offline
post #7 of 18 (permalink) Old 03-08-2011, 08:27 PM
Yup.
I say, third brake light, and plugged drain holes in the rear window.
Remove the rear window and squeaky-clean everything and the drainage holes!
1st Diesel 1995 Ram 2500 || 5.9CTD || 2wd long bed
Home-made KDP fix || 2x electric fans in front of condenser || tinkered fuel-plate and AFC || boost elbow ||
Hit.It. is offline
post #8 of 18 (permalink) Old 03-08-2011, 08:42 PM
68bullittbuilder's Avatar
Is the water in the front of the cab or the back of the cab?? My first thought was that your windshield might be leaking. Also how is the gasket around the passenger side door up at the cab drip rail? If it's in the back then yeah I agree with the guys on the 3rd brake light.
1997 CCLB 330K and counting. 5" DiamondEye, BHAF,SuperB, 4K GSK, AFC mods, AFC LIVE, 5x12's, 055's, ISSPRO EV2's, Revmax Converter, Built Auto...Sure there's more
68bullittbuilder is offline
post #9 of 18 (permalink) Old 03-08-2011, 08:49 PM
Mid-Tenn Region President
CountryMusicCTD's Avatar
Not to hijack the thread, but I have a small leak from somewhere, and I am clueless. Sometimes when it rains (<0.5 inch usually) I'll go out and start her up and drive her, and two or three drops will fall onto the console, or the seat under it (bench). Whenever it does this, I usually am near somewhere and pull over and feel around the headliner, ceiling. I can't find anywhere it's wet. Could this be one of the issues mentioned above? The cowl seal came off and I haven't put it back on.
Truck:
1997 3500 Club Cab, NV4500, Valair clutch, 4 inch straight MBRP TBE, AFE BHAF, Pump tuned, #10 plate, KDP KIA, Isspro Boost and EGT Gauges, Tow Mirrors
Daily Driver:
2013 Ram 1500 Express White QCSB, Vararam Intake, Moe's 87mm PTB, 14" Magnaflow, tuned by Sean at Hemifever
CountryMusicCTD is offline
post #10 of 18 (permalink) Old 03-09-2011, 12:19 AM Thread Starter
ajgroos's Avatar
well i will check the rear window and 3rd brake light but the back carpet is dry to the touch the lake is up front on the passenger side.
ajgroos is offline
post #11 of 18 (permalink) Old 03-09-2011, 11:11 AM
smokin9812valve's Avatar
Same problem, mine is usauly when I run the a/c at all, Im going to try to seal up the area around the drain spout on the fire wall and see if that doesnt fix it. I thought I had the leak when it rained untill I dried it up, turned my a/c off and tried to get it to leak by driving in a downpore and blasting through 6in deep "lakes" on the road at 30mph. All that and nothing. That and it happens even when we dont have rain for quite a while
1998 Dodge Ram 3500 4x4, QC Lb, SRW, NV4500, sb clutch, ddp 90hp sticks, #100 fuel plate, 3k gsk, BHAF, 4-5in exhaust, cobalt guages, 7"lift, 38.5r20 procomp xt a/ts, and a whole lot more crap no one cares about. Most importantly, its got a
smokin9812valve is offline
post #12 of 18 (permalink) Old 03-09-2011, 01:24 PM
flagmanruss's Avatar
Possibly plugged cowel drains... flooding through heater. It's impossible to easily see the drains, located behind the hood hinges.
There should be a drain from the heat/AC box through the firewall... a small rubber hose. Frequently gets plugged... or sometimes get damaged & lets water in! It's where AC tech looks for dye when repairing AC.
Every once in a blue moon, I have water drips from overhead console after a heavy rain... forcing past gaskets on marker lights.
Good advise all around. You'll have to systematically go through all possibilities.
2001.5 Dodge Quadcab, 2500, 5.9, AD150, big line, 47RE auto, 4X4, 4.10, 265/75R16, 8800 GVW, TCW3 4"TBE, 36" FTE swirl resonator, straight through "muffler", IAT (mpg) fooler, XZT+. NRA LIFE MEMBER
flagmanruss is offline
The Following User Says Thank You to flagmanruss For This Useful Post:
CountryMusicCTD (03-09-2011)
