Tires chains and a dually - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 11-17-2010, 10:08 PM Thread Starter
I tried searching here and google and couldn't get a good answer. I have a 2wd dually. If I use single wheel chains on the outer dually tire will the chains rub between the outer and inner dually tires? I can get single tire chains for about $40, but dually chains are about $200. The tires are size 225/75R16 M+S tires.
95 dually auto ext cab Laramie 365k miles, 4k GSK & exhaust valve springs, BHAF, boost elbow, no plate, modified and tuned AFC, rebuilt and ported stock HX-35W, 4" Diamond Eye exhaust, Pyro, boost &, trans gauges! Power 2003 club cab seats!
bjorkmae is offline
post #2 of 8 (permalink) Old 11-17-2010, 11:14 PM
VP Moderator
dozer12216's Avatar
it may touch the inside. However how would that be any harder than riding on outer wheel??
dozer12216 is offline
post #3 of 8 (permalink) Old 11-17-2010, 11:23 PM Thread Starter
Are you suggesting taking off the inside wheel and running the chains or just saying it would be the same thing?
bjorkmae is offline
post #4 of 8 (permalink) Old 11-18-2010, 01:32 AM
I've seen commercial trucks (smaller ones) run single wheel (meaning outside wheel only) chains on dually rears.
I think if they touched it would be ok as long as its not jammed in there and really tight.
50ftkaufman is offline
post #5 of 8 (permalink) Old 11-18-2010, 01:43 AM
ykdave's Avatar
both ideas suck... LOL
running single chain on a dually is pretty much a guarantee that you will chew up the inner sidewalls as the tires balloon out from bumps and whatnot. just depends on how tight the wheels are together
Running a single tire on a dually hub is not the end of the world, but you do put alot of strain on the spindle bearings. again, not the end of the world, but i wouldnt be putting any weight in the bed of the truck
ykdave is offline
post #6 of 8 (permalink) Old 11-18-2010, 01:44 AM
catmike's Avatar
ive been runnig singled out on the rear for a lil while now while i acuried a couple new wheels and havent torn anything up yet
97 3500 ext cab 4x4, nv4500, banks power pack
catmike is offline
post #7 of 8 (permalink) Old 11-18-2010, 09:35 AM
If the chain is sized right and installed properly it won't rub. I would want to do a dry run in daylight and establish where to hook the inners.
1996 CC LB 2WD auto 3.55 BD brake, BD Autoloc, 60# springs, 4K GSK, #5, 15 degrees, DDP AFC spring 7x0088 denso 148 injectors
2007 QCSB 3500 G56
skyking is offline
post #8 of 8 (permalink) Old 11-18-2010, 11:20 AM
hardtailjohn's Avatar
You're not going to hurt anything running a single chain! I've never seen a problem from that.
Yank that outside dual off and run a single tire back there if you want. It will get around a bit better...lots do that here.
John
I'm so far behind, I think I'm ahead..
hardtailjohn is offline
