I've been having problems with the charging system cycling on/off. Tried to track down a shorted wire/connection but no luck so I decided to bypass the PCM & install an external voltage regulator. After reading the posts on here regarding the installation I mounted the new external regulator on firewall, connected field wires from alternator to the regulator according to previous threads. I also connected switched power to the wire at the "top of the pyramid" on the regulator. The system is now charging but is fluctuating from 14-14.5 volts causing a pulsing of the interior lights and headlights. Voltage at the regulator on the two wires coming from the alternator are 14-14.5 volts on the wire with switched power and +/-8-14 volts on the other wire. Is that much of a change in voltage on the other field wire common? Any ideas on how the keep the voltage from cycling & causing lights to pulse? Any help is appreciated.
all the time-from start up when the grid heater's cycling to when it's warmed up & running as normal--everything seems to be ok other than the .5-1.0 volt fluctuation/pulsing that's going on
hmm...thats weird, pulses are normal while the grid heaters are cycling as they draw a lot. Do you know if they shut off...could be something with them constantly cycling and not stopping like they should once engine temps are up.
1995 Dodge Ram 2500 CTD Club Cab 4x4 Long Bed, Auto, 4" MBRP Turbo Back Exhaust, .........
The grid heaters are working as normal--the fluctuation in voltage is very quick (1/2 second or so) and only about 1/2 a volt or so but it does cause a slight flickering in the lights.
I guess my question is...what is the normal voltage output for the two smaller field wires on the alternator? and is that voltage supposed to fluctuate? I made connections according to this diagram from DTR and as show I am reading 14 to 14.5 volts on the red line in diagram and 8 to 14.5 volts on the blue wire in the diagram. Is this typical or what should it be?
it might be the alternator, the alternating creates alternating current and then an internal regulator converts that to DC....I would find a shop that would test your alternator for free or a few bucks....
