Belt tensioner - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 08-22-2010, 05:25 PM Thread Starter
Belt tensioner
How do you tell if the belt tensioner is wore out?? My belt is being pushed into the a/c compressor eating the inner 2 ribs of the belt. Belt does have some slack as it comes up from the a/c compressor to the alternator.
96 CTD,3K,AFC spring,fuel plate,new injector pump
100% WVO last 42,000 mi on 331,000 mi
BHAF ,no cat,no silencer ring.
BeeGee is offline
post #2 of 10 (permalink) Old 08-22-2010, 05:50 PM
ykdave's Avatar
their is actually a fancy little tool you use for checking the belt tension. something like a fish scale, pull xx pounds of tension and you should have xx amount of deflection. Dont recall the specs, but thats how its done
ykdave is offline
post #3 of 10 (permalink) Old 10-09-2010, 07:38 PM
Deplorable's Avatar
Belt tensioner should move side to side about 1/8 to 3/16 of an inch when idle. more than that replace it.
hitting a/c replace it.
Deplorable is offline
post #4 of 10 (permalink) Old 10-10-2010, 02:22 AM
GAmes's Avatar
iTrader Score: 7 reviews
You answered your own question. The two pieces of the tensioner have a teflon disk between them. When it wears out the belt won't run true. Easy to replace, and I recommend you get a genuine Cummins part so you won't have to do it again for quite a few years. (I've only replaced mine once).
97 3500, 2 WD, G56, slightly bombed, 1.2 million miles. Started the second million on 8/24/13
GAmes is offline
post #5 of 10 (permalink) Old 03-25-2011, 10:44 AM
Ram_Breck's Avatar
some pics
So we know what we are talking...
BELT TENSIONER CUMMINS ISB 3912254
97.5 Dodge Ram 2500/2WD/Single Cab/Long Bed/5 Speed Manual /Tires 275-70-R16/New Lift Pump/EGR Delete/150k/Gears: 3.54 / 5.9L 12 V
Engine Oil: Shell Rimula R4 15W-40 CI-4+ Waiting new tires
Ram_Breck is offline
post #6 of 10 (permalink) Old 03-25-2011, 02:58 PM
Can you replace just the teflon piece or is it best to replace the whole tensionor
Also how do you change it I can't get the tensionor to "relax" before my breaker bar hits the fan thanks
2011 3500 CCDRW Auto, 4x4, 6" black aussie stacks, Bully Dog GT, AFE Stage 2 Dry CAI, spray in bed liner, B&W Turnover Ball, 2.5" HBS Leveling Kit, 255/80/17 BFG KM2
Nadep_Cowboy is offline
post #7 of 10 (permalink) Old 03-27-2011, 10:22 PM
GAmes's Avatar
I don't think there is a source for the teflon piece. The bearing wears and the spring loses tension, just replace the assy.
I don't know what to tell you. Try using a ratchet.
GAmes is offline
post #8 of 10 (permalink) Old 03-29-2011, 11:30 AM
Ram_Breck's Avatar
I had problems with the piece of teflon, I had to replace with a rolled steel, which can be disassembled and maintenance of the bearings.
I'm sure you can change the piece of teflon.
post #9 of 10 (permalink) Old 03-30-2011, 12:04 AM
Is the mount bolt left or right hand threaded.
post #10 of 10 (permalink) Old 03-30-2011, 12:22 AM
So the question is???
9612vinva's Avatar
normal thread....
97 ECLB Manual...2ndGenDoms trucks EVIL TWIN
Originally Posted by v8440 View Post
There's a guy floating around here with 780k on his unrebuilt cummins. Now, according to duramax and ford guys, his truck should have fallen completely apart around the engine 7.8 times, since they all know that dodge trucks are junk and only last 100k before they spontaneously disassemble themselves while going down the road. That has happened to me 2.76 times, and both times I was only wearing boxers while driving so it was really embarrassing.
9612vinva is offline
