Rear brake line - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 08-13-2010, 09:16 PM Thread Starter
Rear brake line
My rear brake line in the frame rusted away behind the fuel tank. I want to replace it before it blows out. I dont know the size of the line or what ends are on the line. Does anyone know anything about the size and the fittings. I called the local dodge dealer and they cant tell me what size the line is or what size the ends are.
sherbstrd350 is offline
post #2 of 8 (permalink) Old 08-14-2010, 02:48 AM
macd's Avatar
My christmas gift to all of you there's a service manual. Go to an auto parts store they can help you out.
98.5 2500, auto, 4x4, 4in turbo back, afe intake, adrenaline, Raptor 150, 1/2" lines,4 in. Kore lift, 37/12.5/16.5 Wrangler military MTs, tonneau cover, bigger sticks, Big head wastegate actuator, turn over ball and rapid hitch.
macd is offline
post #3 of 8 (permalink) Old 08-14-2010, 06:45 AM
It's standard 3/16" steel brake line. You can buy it in precut lengths, preflared and with fittings. If you've never flared steel line, it takes a little practice and a double flare kit. Most inexpensive way is the precut lengths. Your best bet is to replace the entire line from left front wheel to just before rear end where rubber line attaches to the steel line.
RPegram is offline
post #4 of 8 (permalink) Old 08-15-2010, 12:25 AM
12vCTD's Avatar
best fix is to buy a prebent stainless brake line kit and swap them all out, i plan to do mine soon the brakes lines are rusty, my fuel lines are just scary though!!! got some 3/8 stainless line for them i swear if you breath on them they would leak!!!
99 3500 4x4 quad cab CM flatbed, built auto, ppump swap, Maxspool cam, dual valvesprings, hd pushrods, fass titanium, BW S362 fmw, 5 inch exh , guages, 125 inj ,head studs, Eaton m112 supercharger
12vCTD is offline
post #5 of 8 (permalink) Old 10-09-2010, 07:57 PM
Deplorable's Avatar
I have done this job in my driveway and spent about two days doing it. 3/16 brake line and a double flare tool and bender. make sure to bleed all wheels.
Deplorable is offline
post #6 of 8 (permalink) Old 10-09-2010, 09:32 PM
FF1063's Avatar
You should check all of your lines, I replaced all my lines and hoses, bought a 50 ft coil, green epoxy coated stuff, bends easy by hand, does not kink.
I eliminated most of the junction blocks and made straight runs. No more worries about blowing lines, happened 2x !
2014 RAM 3500 4X4 DRW CTD 24V
1998 RAM 3500 4X4 DRW CTD 12V - Gone !!
FF1063 is offline
post #7 of 8 (permalink) Old 10-31-2010, 09:46 PM
sy552's Avatar
Mine was rusty behing the fuel tank. I just bought a new rear line from the dealer. They are pre-bent and it was only about $30.00.
01 Ram 3500 QC 4x4 4.10
4" exhaust, Edge Juice, Raptor pump, draw straw with Vulcan big line kit, 3rd gen 17" wheels and front brakes. 1,500,000 miles and still rattlin' down the road
sy552 is offline
post #8 of 8 (permalink) Old 11-01-2010, 04:14 AM
WhiskeyRider's Avatar
Im a big fan of 1/4" hydrualic hose myself.
'96 2500 RCLB, 47RE, 241HD, BHAF, Tuned AFC, #8 Plate, KDP'ed, MBRP T-B 4"-5" tip, Silencer Ring Gone, Skull Valve Stem Caps. In the works: 5" Lift w/6" coils. Dually Convert. Highway Products flatbed.
WhiskeyRider is offline
