Oil Pressure Problems...Help - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 07-30-2010, 10:17 AM Thread Starter
Just my luck, i went and pickup up a 98 12 valve last night. Drove it 2 hours home, no problem, get home and drove it to work today, coming home i hear the ding ding like my doors open, look down and the check gauge light is on and the oil pressure gauge is sunk down to 0. Seems to happen when im decellerating on coming to a stop. Any help would be appreciated, just sucks spending all the money on something that know im afraid to even run. (don't really have much to fix it)
Sending unit??
Pull pan and clean screen??
Clean/Replace pickup tube
Check over pressure bypass valve??
Just a few things ive heard to do.. but they were more on gas motors, if anyone could help i'd greatly appreciate it. Thanks in advance, Nathan
98 12v. HX35. 45 horse injectors. 191 Delivery Valves. 0 Plate. BHAF. 6'' side exhaust. Leveling Kit. 35'' DC Mud Country's on Helo Max's. Towing Mirrors. "BulletProof" Trans. Silencer Ring Removed. Gauges (boost,trans,egt). Boost Elbow. Pump work
boosted4life is offline
post #2 of 12 (permalink) Old 07-30-2010, 05:03 PM
First thing to do is to go get yourself an elcheapo mechanical oil pressure gauge and verify the pressure. There is a 1/8" port on top of the oil filter housing you can use. If pressure is good, then sender is bad. Get yourself a new Cummins sensor. If oil pressure is low, then time to start tearing her down to find the problem.
RPegram is offline
The Following User Says Thank You to RPegram For This Useful Post:
Barney R (08-03-2010)
post #3 of 12 (permalink) Old 07-30-2010, 08:59 PM
FF1063's Avatar
Common intermittent problem, always sender related.
2014 RAM 3500 4X4 DRW CTD 24V
1998 RAM 3500 4X4 DRW CTD 12V - Gone !!
FF1063 is offline
The Following User Says Thank You to FF1063 For This Useful Post:
post #4 of 12 (permalink) Old 07-30-2010, 09:13 PM
ykdave's Avatar
x3 on the sending unit. its the issue 99% of the time
Cummins replacement only, el-cheapo parts store units will crap out fast...
ykdave is offline
The Following User Says Thank You to ykdave For This Useful Post:
post #5 of 12 (permalink) Old 07-30-2010, 09:52 PM Thread Starter
I figured, i plan on pulling the oil pressure gauge out of my civic and put in there. But does anyone know where the Cummins dealers are in Ohio?? Anyone have a list of them or something, im located in Loudonville Ohio 44842
post #6 of 12 (permalink) Old 07-30-2010, 09:53 PM
ykdave's Avatar
go to the cummins website and search for a dealer
ykdave is offline
post #7 of 12 (permalink) Old 07-30-2010, 10:28 PM Thread Starter
Unfortunately it doesn't look like there is a Cummin's Dealer around here... Guess ill be going to Underwoods dodge....
post #8 of 12 (permalink) Old 07-30-2010, 10:41 PM Thread Starter
If i throw my autometer oil pressure gauge in there and it's reading alright (what do you guys consider alright??) Im used to 4 cyl. Can i drive it until i get the sending unit it replaced or will the sensor going off be bad for the truck??
post #9 of 12 (permalink) Old 08-03-2010, 11:05 AM
Thank You, Thank You, one and all. And a special thanks to RPegram for the tip on the 1/8 access on top of the oil filter.
I bought this truck new in 1995. It is a 1996 with a 5 speed manual. I started it last week and the motor sound was fine, but the oil pressure gauge was at 0. At 1700 rpm the gauge shot up to 40 psi.
I shut it down and started searching the repair manual. I changed the oil and filter first and had the same results.
I found this site and your input and I bought (as suggested ) an elcheapo manual gauge and accessed the 1/8 port on top of the oil filter and got a steady 50 psi reading. So I will order a cummins sender. Thank you all again.
Barney
Barney R is offline
post #10 of 12 (permalink) Old 08-03-2010, 08:49 PM
If you are sure its the sending unit. It won't hurt to run it as long as the check engine chime dosen't drive you crazy. I drove mine for over a year with the same issue. It got more frequent over time and I couldn't stand it any more.
98 2500 QCLB 4X4: G56 SIX SPEED: VALAIR DD CLUTCH: DANA 80 W/ 3.54 GEARS: 315/75-16 RUBBER: COLD AIR INTAKE: ADJ. BOOST ELBOW: 4K GSK: 60# VALVE SPRINGS: AFC MODDED #10 PLATE: HX35/40 HYBRID W/ 4" POWER ELBOW: 4" EXHAUST.
Ed Font is offline
post #11 of 12 (permalink) Old 08-03-2010, 09:05 PM
ykdave's Avatar
as long as you have at least 10psi per 1000rpm your good to go. Running it with a dead sending unit is not going to hurt anything, just be annoying to have the oil light on all the time!
ykdave is offline
post #12 of 12 (permalink) Old 08-06-2010, 01:41 AM
J REED '98 6BT's Avatar
It seems there is a known problem with '98 12 V engines. The first time it happened to me, I . The truck still runs fine. The problem is the sender/ gauge cant read low pressure, enough to make the "ding , ding" go off. The only real fix is to reflash your ECM to read idiot speak " more than 5 psi" or put a live OPG in the cab, or just live with it. Do a search on this.
11/97 2500 Club Cab 4WD NV 4500 3.55's # 11 Plate, 16* timing , 285/75/16 , 220,XXX miles...
J REED '98 6BT is offline
