sagging headliner fix? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 22 (permalink) Old 06-30-2010, 08:10 AM
ztk7220's Avatar
i just put fabric glue on while it was up not the best fix but easier than taking it all off
97' ,12valve , 5 speed NV4500, 35x14.5x17 tires on Eagle Alloy wheeles , 5in lift ,no plate,afc ff starwheel turned a bit, boost, pyro, fuel pressure gauges.
ztk7220 is offline
post #14 of 22 (permalink) Old 06-30-2010, 09:48 AM
calteg's Avatar
Originally Posted by kayden101 View Post
interresting. dont mean to highjack but what year models will fit right in a 94-98 model..
I pulled mine out of an '01. I assume the 99-01 will drop in...not sure when Dodge went to the larger overhead design.
95 Ram 3500 - Auto, 2WD, BHAF, 4" straight pipe, silencer MIA, Autometer gauges(boost, trans, pyro) Mag-Hytec 727DD, KDP tabbed
calteg is offline
post #15 of 22 (permalink) Old 11-07-2010, 01:26 AM
You said you pulled one from an '01, but you assumed that the 99-01 style retrofits. Now that it's a few months later, can you tell us if it fits? I need to replace my overhead console and the housing for the 94-98 style is no longer available - if I can go with the 99-01(or 02?), that will widen the possibilities... Thanks for any insight you can provide!
'96 2500 club-cab, long bed, 2WD - Dipricol gauges, +2qt Chrysler trans pan, Sport headlight retrofit & suvlights conversion harness
texasprd is offline
post #16 of 22 (permalink) Old 11-09-2010, 01:04 PM
i tried to reglue fabric to it and like 3 months later it started to sag again, so i pulled all the fabric off and hit the foam with duplicolor rubberized undercoat, and then my visors, overhead console, handles, etc with their fabric and vynal paint to match the black, it looks pretty good and i like it, except it smells like paint in the truck now and its like huffing everytime i drove anywhere, but the smell doesnt last too long
95 2500 sclb, no fuel plate, afc gutted, 18* timing, 4 inch exhaust, wastegate restricted, 2 1/2 inch leveling kit, glowshift gauges,suncoast tc, georend vb, billet input, (props to jessie harris
StrippedGear is offline
post #17 of 22 (permalink) Old 11-09-2010, 11:23 PM
sdiesel's Avatar
the headliner material will need to be removed and new glued on; use the heavy 3m stuff
there are two levels of strength in that product
cause i am working on myheadliner right now
there is an outfit called raamaudio that deals in sound control for high end competition audio.
he has a product that is called ensolite it is sticky back and it KILLS sound reverberation.
its closed cell and its a flat black in color
it goes on easy and if the foam is removed with a knife it will stick to the fiber real nicely
i have done all of my cab with it ;inside the doors and all
1994 3500 dually build date:12-93 new:trans, t case, cage long arm suspension sulastics, pre filter/heater MIA / HX35/40 4/5inch exh more much more
sdiesel is offline
post #18 of 22 (permalink) Old 11-10-2010, 10:42 AM
Gasoline Sucks's Avatar
the Michael's fabric store down here had actual headliner in stock make sure you ask and see if they have it. Its nice stuff and was cheap, about 30 bucks with the glue!
96 12v 4x4 regular cab, kdp killed, BHAF, 5in farmboy's exhaust, fuel plate MIA, 4kgsk, AFC mods, 22s 33s, 3:55s, pyro, boost, trans*, fp, Stg 3 Snow perf water/meth, BILLET ATS, 5x16s, 62/65/14, timing ~17.5 (thanks vinylman!) mack plug
Gasoline Sucks is offline
post #19 of 22 (permalink) Old 11-13-2010, 08:40 PM
FiveNdime's Avatar
FYI, you might want to call your local fabric store to verify the size. I drove 45 minutes to my "local" store, I live out in the country you could say. They had foam backed grey and tan head liner material but it was only 54" wide which is not wide enough. you need at least 58" and that's a tight pull. I would recommend going to your local auto upholstery shop or online. I found this website and I'm thinking about ordering some from them. You can get by with 2 yards if your only doing the head liner in a club cab truck but if you want to do the visors you will need 3. Here is a link for that site.
Automotive Interiors - interior kits, carpet kits, seat covers
96, club cab, 5spd, 4x4, long bed, 4" Diamond Eye with muffler, BHAF with heat shield, AFC Mods, Fuel Plate Removed, Valair Kevlar/Ceramic 13", Sunpro fuel pressure boost and egt gauges, 5 1/2" lift on 35's.
FiveNdime is offline
post #20 of 22 (permalink) Old 11-14-2010, 10:07 AM
Trucks
Great episode of Trucks, goes into headliner replacement and lots of other cool stuff for a 2nd gen.
97 12v 5sp 4x4: 5x.012 FBD Injectors, 60mm Upgraded HX35 from HTT, 19* Timing, 4K GSK, ARP Head Studs, BHAF, 4" Exhaust, Random other go-fast stuff...
Also: 01 Ram v8, 94 GMC 6.5L Diesel, 02 Jeep TJ v8, 82 Trans Am v8... and no free time
Phantom1016 is offline
post #21 of 22 (permalink) Old 11-15-2010, 08:55 PM
head liner
I just did mine used the kit from jc whitney. the tan was the same as my original. the hardest part was getting the old foam off. I used awire brush in drill
95 2500excap longbed tabbed KDP
nitemech is offline
post #22 of 22 (permalink) Old 11-16-2010, 02:03 AM
jnicewan's Avatar
A few tips for headliner work.
3M Super 77 spray adhesive
It can help having a small paint roller and new roller brush to help smooth and attach fabric to glue
Get some insulation and/or sound deadening mat to apply to roof when headliner is out
If you are considering adding cab clearance lights, now is the time to do it.
98 12v, 48RE, Revmax kit, V/B, triple disc stage 5, ultra low stall with a few other billet pieces. AFC modded, 100ish plate, 16.5ish*, KDP gone, 60lb springs, 4K-GSK, BHAF, pyro, trans, boost guage. , 72 AM general M35A2 LDT465
jnicewan is offline
