Cruise control not Working - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By Ram1995
post #1 of 9 (permalink) Old 04-20-2017, 06:33 AM Thread Starter
Ram1995's Avatar
Exclamation Cruise control not Working
Hi everyone I am Italian I use the translator to write, congratulations to the forum, I found so much useful information, I have a problem on my Ram 95 5.9 cummims the cruise control does not work, the vacuum lines are ok and it works ac / 4wd and fuses Okay, do you think I should check the cables in the steering wheel? Thank you all in advance!
Ram 5.9 cummims & chevy camaro 5.7 "79
Ram1995 is offline
post #2 of 9 (permalink) Old 04-20-2017, 06:52 PM
Smokeycummer
Smokes when she drinks's Avatar
Is your air bag light on ?
97 Eclb( 4 door 2002 body) 4x4 ,180 Farrell maxed pump ,pdd 5x14s, 7mm dvs ,afc live 2 ,allen head bolts 120 ft lbs ,19 degrees ,
Adjustable tork tec ,he351cw, Gage's fp , boost , trans temp , egt , single billet tc ,built trans , straight pipe, bhaf , pot mod
Smokes when she drinks is offline
post #3 of 9 (permalink) Old 04-21-2017, 07:10 AM Thread Starter
Ram1995's Avatar
Yes airbag light on!
Ram1995 is offline
post #4 of 9 (permalink) Old 04-21-2017, 07:18 AM Thread Starter
Ram1995's Avatar
Today i checked the vacuum tubes i am ok ... but i saw that the engine under the battery and the keys on the steering wheel does not have any 12 v ... the fuses in the cabin are ok
Ram1995 is offline
post #5 of 9 (permalink) Old 04-21-2017, 08:09 AM
Smokeycummer
I'm pretty sure if your clock spring is bad it will not let cruise work and turn on air bag light .
post #6 of 9 (permalink) Old 04-21-2017, 08:28 AM
The "clock spring" is part of the electrical wiring inside the steering wheel, where it goes from able to turn to fixed wiring. Both the steering wheel air bag wiring and the speed control wiring must pass through.
97 2500HD Club Cab, 4x4, automatic. Isspro Gauges (great support!), Tork Tek OFV (great support!), Diamond Eye SS 4" exhaust (good product).
Chapin, SC or Avery, TX.
DanG144 is online now
post #7 of 9 (permalink) Old Yesterday, 04:17 AM Thread Starter
Ram1995's Avatar
Hello guys and thanks to the advice ... as it was written i guatdated the wires inside the steering wheel and the cause of the cruise control not being the wires just broken in the steering wheel .... now airbags and cruise control work well i really thank you For the advice we feel soon in the forum
Ram1995 is offline
post #8 of 9 (permalink) Old Yesterday, 04:19 AM Thread Starter
Ram1995's Avatar
You're right the problem is that
Ram1995 is offline
post #9 of 9 (permalink) Old Yesterday, 06:26 AM
Smokeycummer
No problem glad it worked out for you
