- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 94-98 Non-Powertrain Discussion of 94-98 Topics Not related to the Powertrain...NO ADVERTISING |
#13 (permalink) | |
My truck is a 1998 with 24V and the headlight switch update 819 package for 1994-1997 fit just fine.
#15 (permalink) |
alright sweet thanks for checking man
Fuel: Contagious Diesel 5x.014 Injectors, 4K GSK, 0 Plate, 19* Timing Air: Borg Warner 63/68/.88 S300SX Trans: Dunrite 3 Disc T/C, Performance V/B, Mag-Hytec DD Pan, Amsoil Fluids |
#16 (permalink) |
![]() Join Date: Apr 2006
You can get new headlight switches from Rock Auto (.com) for about 30.00, nice quality. You will need to transfer some parts from your old one, easy to do. After doing the new switch route, I still had headlight issues. Remove the switch and look at the connection of either the red or green wire, can't remember which, but it is the BIG one on the upper left side of the switch. You can carefully cut the plastic away, exposing the crappy low surface area connection. Remove the connection and get rid of the clips. Clean everything and solder it back. Far better connection, better transfer of juice, brighter lights, less heat.
96 reg cab, 5sp long bed 4x4: 10 plate, 3GSK, pump @15, AFC altered, K&N, gasket matched and ported exhaust manifold, 4" exhaust, gauges, KDP KO'ed, Dynatrac axles and hubs, airplane landing lights, Dana Powerlok's front & rear, runs on WVO. |
#17 (permalink) |
Ok, the answer from my friend. Yes, it is a easy swap to bolt it in, but the wiring has to be almost completely redone. Also, the V.I.N. tag is attached to the dash on 94-97 trucks, and to the cab on 98 newer trucks so consequently you'll lose you V.I.N. tag if you remove the original dash.
#18 (permalink) |
alright, well thanks for looking into it for me, maybe it will be my winter project if i get some money
97 white 2500 5 speed 4x4, broke 93 toyota pickup |
#19 (permalink) | |
Thanks in advance! |
#20 (permalink) |
As far as the VIN goes, you can pop rivet it to the new dash. That's what the dealer did to mine when it was new because the dash had been damaged by someone who stole the radio out of in on the train before it got to California.
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4, 3.54, EGT, boost, fuel pressure, trans temp guages, PacBrake, TST #5, DTT VB, DTT triple disk TC, DTT billet flex plate, Cummins chrome kit. |
#21 (permalink) |
Before you replace it. Check the actual connections inside the plugs. I have had two that it was the crimp on the actual connectors that weren't making good contact. I had already bought the replacement switch for one before I found the problem.
