Old 11-14-2009, 05:04 PM   #1 (permalink)
01Cummins24v's Avatar
No speedo after 5spd swap
Ok I just completed my 5spd on my 1997 cummins. While doing the swap I removed the gauge cluster to put a peice of electrical tape over the p r n d indicator in the middle of the gauges while doing that I wiped the faces of all the gauges off moving the needles a little to clean them. After getting the truck running no speedo, so I replaced the speedo sensor on the transfer case still no gauges so I pulled the dash back apart and everything is all connected but still no speedo. Does anyone know how to fix this?
1997 4x4, 5spd, Valair 13" single disk, BHAF, 4k GSK, #100 Plate, AFC tweaked, 6" Mitre Cut Stack, Autometer Gauges, KDP tabbed, leveling kit. 35's, Moto Metals
Ohio Coal Rollers
01Cummins24v is offline   Reply With Quote
Old 11-15-2009, 10:43 AM   #2 (permalink)
come on guys i need some help
Ohio Coal Rollers
Old 11-15-2009, 03:17 PM   #3 (permalink)
well today on a 20 mile highway trip my speedo started to work for a minute. l was doing about 55 and it bounce back and forth from 0 to 10mph and it tracked .7 miles so can anyone tell me whats wrong? should l try another speed sensor or what. someone has to know something.
Ohio Coal Rollers
Old 11-15-2009, 03:19 PM   #4 (permalink)
double post
Ohio Coal Rollers
Old 11-15-2009, 03:22 PM   #5 (permalink)
VX KILLA
NOSPARK's Avatar
check all your connections, sounds to me like you have one loose. also check all fuses
04.5 2500 QC/SB 4x4
NOSPARK is offline   Reply With Quote
Old 11-15-2009, 04:31 PM   #6 (permalink)
already went over them everything is good...
Ohio Coal Rollers
Old 11-15-2009, 04:36 PM   #7 (permalink)
Make sure you speed sensor is indexed properly and engaging the output shaft.
RPegram is offline   Reply With Quote
Old 11-15-2009, 09:30 PM   #8 (permalink)
how do you do that? The sensor is held in by a fork that thats pushed down by a 13mm bolt and is sealed by an o-ring l dont see how the depth of the gear could really change but l could try it if you could explain how to check it.
Ohio Coal Rollers
Old 11-16-2009, 04:53 AM   #9 (permalink)
The gear on the end of the sensor inside the transfer case is offset. It needs to be installed so the gear is "up" engaging the splines on the shaft inside the transfer case. Remove it, turn it around and look at it and you will see what I'm saying. If memory serves me correct, the plug should be at the top of the sensor when it is installed in the case.
Old 11-16-2009, 12:24 PM   #10 (permalink)
l will try thay thank you for your help
Ohio Coal Rollers
