| 94-98 Non-Powertrain Discussion of 94-98 Topics Not related to the Powertrain...NO ADVERTISING |
Need wiring help
I have some lights to put on my truck and i need some help with the wiring. I am good at wiring and have wired many things up on atv's but now i want lights on my truck and i need to make sure i do everything right. I will be using relays which i haven't used before and don't really understand the little diagram on the front of the relays so i need some help. I have to post a link because i can't download this picture can you guys help me on which wire goes to each pin. Thanks
1996 ram 2500 ext. cab 4x4 auto |
#2 (permalink) |
Cummins Power Addict
![]() Join Date: May 2008
First, that relay is more then you need. Depending on the lights you're talking I guess. Can't tell for sure without the pin diagram too, but a relay is pretty basic. You have power (straight from the battery) coming in to one pin. Then you have that power going out from a pin (usually across from the other one?) to your lights. You then have a pin for a switch... if there's power to that pin the relay closes the circuit inside, if there's no power (ie switch on or off) the relay opens the circuit. Some 4pole relays use the 4th pin as a normally closed shutoff (meaning, fog lights... if you turn the brights on it turns off the fogs). The 5pole you have would be a similar set-up... the top of the relay should say what it all does... but you're basic 3 is all you need I'm thinking. Power in, normally open switched, and a power out.
'98 2500, C/C, S/B, 12v, 5spd, 4x4, CAI, TST #12/BoostElbow, 4kGSK, BD Exhaust Manifold, AutoMeter Gauges, Bullydog 4" TB Straight Pipe, AR Outlaw IIs with Nitto Terra Grapplers. '04 Sterling Acterra 3-ton; '98 Durango SLT, 318/4spd/4x4; '79 Chevy C10 R/C, L/B, 350-4bbl, 3spd auto www.stupidproductions.ca (Personal Website - Vehicle stuff) |
#3 (permalink) |
Pins 85 and 86 is for the control circuit. The switch usually hooks up to 86 and 85 goes to ground. But it can be reversed. It is not polarity sensitive. Pins 30 and 87 are the power pins that turn the lights on. Power goes to pin 30 and 87 goes to the lights. Here is a schematic that will help. Here |
#4 (permalink) | |
#5 (permalink) | |
#6 (permalink) |
One more question how large of a wire will i need to run in the cab to the switches i would like to go about as small as possible
#7 (permalink) |
For the switches it really won't matter. I'd honestly use whatever I have around, it's very, very low amperage going through the switch... just enough to power the relay. Someone else might have a better idea, 22 might be too small, 18 should be fine I'm thinking.
#8 (permalink) |
Have you thought about HID's??? It would sure save some wiring and amp draw on your alternator. check these out i put 4 on my replacement bumper
96' 3500 Reg Cab 4x4 Leveled on 35"s HX35/40 Hybrid, Custom intake box w/ AFE BHAF, O-Ringed Head, Ported exhaust, 4" turbo back, 5x12's, #0 Plate, Gutted AFC |
