Old 11-07-2009, 04:49 AM   #1 (permalink)
best oil
what is the best engine oil for a 12 valve 1995
shaneserle is offline   Reply With Quote
Old 11-07-2009, 07:09 AM   #2 (permalink)
Most name brand DIESEL rated oils will work fine. Rotella, Delo to name a couple. There are some synthetics also. Most use around the 15/40 weight.
RPegram is offline   Reply With Quote
Old 11-07-2009, 08:57 AM   #3 (permalink)
I use either Vavoline blue 15/40 or Mobile delvac 15/40
02/power puck/AirDog100/4"Magna Flow/Glow Shift Gauges/led's/new crystal headlights with 9004su lamps/next project restore my 78 Warlock
hunky57 is offline   Reply With Quote
Old 11-07-2009, 12:50 PM   #4 (permalink)
ram tuff96's Avatar
i like the mobil 1 15-50 fully synthetic you can get a 1000 or some more out of your oil life
96 12v, Driftwood, all orginal47re (even the fluid and filter), 188k, 4x4, 3.54's limited slip, 285/75/16 nitto terra graplers on poished alumin 16's, starwheel tunning, k&n, stright piped out b4 rear tire!
ram tuff96 is offline   Reply With Quote
Old 11-07-2009, 01:35 PM   #5 (permalink)
12VRattler's Avatar
Search is your friend......there are dozens and dozens of topics about oils. Go with a 15 40 CI rated oil and you won't likely go wrong. Personally I have been using Valvoline Blue 15/40 but will likely go with Amsoil synthetic after I fix all my oil leaks.
1996 2500 12v/nv4500 4x4 335k miles and still going strong!! KDP tabbed, Amsoil 4510 BHAF, evicted silencer ring, plugged wastegate, 5 inch FBE muffled, #100 plate, Isspro boost and pyro, Mickey Thomson ATZ's 285/75R16's, B&W steel flatbed
12VRattler is offline   Reply With Quote
Old 11-08-2009, 09:56 PM   #6 (permalink)
lance0730's Avatar
amsoil rocks. its expensive but worth it because of extended oil drain intervals.
1996 3500: Full billet DTT, pac brake, #10,timing,AFC,3GSK,Raptor100,58/14 Hybrid, lockup controller,3 piece,CFM
lance0730 is online now   Reply With Quote
Old 11-09-2009, 05:02 PM   #7 (permalink)
Just so I don't have to make a new thread about the same topic.
Does anyone use Mobil 1 5W-40 full synthetic? If so how is it? Its rated for turbo diesels but im used to using 15W-40 so i'd rather check here before buying some.
97 single cab 4wd 4-inch straight piped, BHAF, autometer colbalt pyro, autometer boost, Ground Plate, ATS 5000, South Bend 550 clutch, 150 sticks, 3k springs.
weatherhead_03 is offline   Reply With Quote
Old 11-09-2009, 05:29 PM   #8 (permalink)
really can't go wrong with anything diesel rated if you change it every 10k. The best oil of any particular manufacturer is the straight 30w, but if you get cold temps you will want a multiweight for winter. Unless you are in a really cold area, you should not need to get outside the 15-40 range. The only one I have had any issues with was Castrol, and I am not sure it was the diesel rated version. when I changed it, it had lost most if it's viscosity and had blobs of sludge in it after a summer of some of the heavier towing I have done.
New: 2008 black MegaCab, 6.7, 4x4, auto, stnd gears, no performance mods, only 14k miles so far
Old: 1997 extended 5.9, 4x4, 5sp, 150k miles, mostly stock but added edelbrock shocks
bart9505 is offline   Reply With Quote
Old 11-10-2009, 02:42 AM   #9 (permalink)
ram tuff96's Avatar
I Wouldn't Run That 5w-40 U Will Probly Have Very Low Oil Psi
Old 11-12-2009, 12:23 AM   #10 (permalink)
12VRattler's Avatar
How would 5w-40 cause low psi? Its the same viscosity as 15w 40 at operating temp but a little thinner when cold. 5w 40 might be necessary for very cold climates.
