Old 11-06-2009, 01:01 PM   #1 (permalink)
Fuel gauge stuck on full
Hi all;
I bought this truck a couple of weeks ago. Everything except the front vents worked fine - more on that later. Yesterday, for some reason, the fuel gauge went to full. When I turn the truck off and take out the key it goes to empty, but goes right back up to full when I start again. I'm thinking an electrical issue? But does it sound familiar to anyone?
Now, with the front vents; I traced it to a broken and very brittle vacuum line running along the firewall and into the cab on the passenger side. I temporarily fixed it with some tubing but I know it'll break again soon. Is there a good place to buy this rigid vacuum tubing? There's no Dodge dealer in town anymore and all of the parts store folks look at me funny when I ask about hard vacuum line.
1998 12V 4x2 Short bed
Pretty much stock because I'm afraid of upcoming smog rules for diesels here in the PRK.
Peragro is offline   Reply With Quote
Old 11-06-2009, 03:54 PM   #2 (permalink)
deyell01's Avatar
For the fuel guage I have had that happen to mine when I fill the tank to full. It stays up there for a while but will eventually come back to normal.
98 3/4 ton extended cab, 5 speed, cold air intake, star wheel cranked, fuel plate and AFC full forward, guages, straight piped. 305/70R16 mud terrains on Eagle Alloys. 2003 chevy buckets.
deyell01 is offline   Reply With Quote
Old 11-06-2009, 07:47 PM   #3 (permalink)
arxalot's Avatar
Stuck fuel gauge
Had the same problem when I purchased my truck. Gauge showed full when the key was turned on. Had to drop the tank and replace fuel "sending unit" on the side of the fuel module. Think it cost around 40$-50$ from the dealer. Not a big deal...just a couple of hours of time.
1998 2WD "Grail" 12-Valve (All Stock....for now)
arxalot is offline   Reply With Quote
Old 11-06-2009, 07:58 PM   #4 (permalink)
Smoke?Check's Avatar
Wish mine said full, its always on E, and I have to look at the idiot light. I need to find time to replace my sending unit
1994 3500 2wd reg cab dually 12v 320k miles dont know what all is done to it. str8 pipe and no fuel plate. soon to be black all over. bbm pin me 31ca1e95
Smoke?Check is offline   Reply With Quote
Old 11-06-2009, 09:01 PM   #5 (permalink)
Moderator
Sometimes you can fix the stuck on full problem by kicking or hitting the tank with rubber mallet.
Some senders tend to get stuck on full when people fill the tank to the brim.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Not stock
Old 11-07-2009, 09:41 PM   #6 (permalink)
So I went out to the desert today and drove on some nice washboard dirt roads. That seemed to do the trick. Fuel gauge is now back to reading whatever it thinks the fuel level is.
Thanks for the replies.
