Old 11-05-2009, 08:14 AM   #1 (permalink)
94 power mirror switch
I have a 94 3500 that I have installed Kool0Vue power tow mirrors on.
The truck never had the power mirror switch & I have found that the 94 used a different switch than the 95-96 & 98 to 2001 used again a different switch.
Can I use any of them-(junk yard finds) or should I order the 94 switch??
Thanks
1994 Dodge 3500 4x4,3.73, converted to single wheel,Cummins,fuel plate ground, 5"exhaust, 315/70/17 Firestone M/T on 2005 factory wheels
rb69 is offline   Reply With Quote
Old 11-05-2009, 12:55 PM   #2 (permalink)
the black monnster's Avatar
ahh ive never herd of anyone using on off of a newer model u may just wanna go ahead and by the one that is for ur truck cus a newer one might be set up diffrent and the relay might not work since it could be a diff set up
1996 CUMMINS QCLB, 4X4, 370 MARINE INJECTORS, ATS TRANS, 4IN TURBO BACK EXHAUST TO A 5IN TIP, BD TOURQUE CONVERTER, TC LOCKUP SWITCH, NO FUEL PLATE, 18IN CHROME WHEELS 35" TIRES, AND SOME PUMP TWEAKING TRICKS I NEED MORE MONEY
the black monnster is offline   Reply With Quote
Old 11-05-2009, 07:17 PM   #3 (permalink)
Super Moderator
LaMoparPower's Avatar
Dodge Ram - Towing Mirror Upgrade Information- '94 to '06
good write up on the wiring..
96' CCLWB 4x4, 22's, blacked out.... still has factory cat and muffler! its a work in progress
Big Thanks to Wally At FTEDiesel!!!!!
Enter the FTE FASS giveaway HERE!!!!!!!!!!!
LaMoparPower is offline   Reply With Quote
Old 11-05-2009, 07:41 PM   #4 (permalink)
thanks to both of you. I ordered the 94 switch from LMC, no longer aval. from the dealer or local parts stores.
LaMoparPower, I have that link & is going to be a great help/.
Many thanks
Old 11-05-2009, 07:46 PM   #5 (permalink)
anytime mann
Old 11-05-2009, 10:50 PM   #6 (permalink)
Super Moderator
I have a switch for a 96'
Old 11-05-2009, 11:00 PM   #7 (permalink)
not sure how that would work with a 94??
I orderd today a switch from LMC.
Thanks
Old 11-09-2009, 07:55 PM   #8 (permalink)
I got everything together, but the rear part of the power mirror switch hits the nut & bolt of the mirror whe you go to put the screw in the upper part of the door panel. I trimmed the end of the screw, but still hits.
What have some of you done to get clearance???
Mirrors work great, but drivers side up & down is slow compaired to the other.
