Old 11-02-2009, 10:26 PM   #1 (permalink)
hoytarchery7's Avatar
what do i need for a 5" exhaust
my friend is gettin an 8" stack and he is useing part of his 5" regular exhaust to go into the stack and i want to get the part that he isnt useing from under the cab back to a 6" tip, my question is what pieces do i need to splice into his 5" pipe cause idk what all they use when they put a stack on with part of the exhaust thats already there, oh and his truck is a 99 extended cab short bed 24v and mines a 94 reg cab long bed 12v so would his 5" exhaust even fit my truck? the exhuast is only 2months old and is made by "pypes" not sure y he wants a stack already.
and he said there is some kinda kit i can get for it that is like $20 that i can splice into his 5" pipe from my down pipe i think he said
94 reg cab 12valve, #10 fuel plate, 4" strait pipe, the rest is stock.
hoytarchery7 is offline   Reply With Quote
Old 11-03-2009, 07:17 PM   #2 (permalink)
Bluedually4x4's Avatar
If your down pipe is stock you need a 3" or 3.5" to 5" adapter. Napa or most exhaust shops could sell you one. On second thought you might need to go 3 to 4 than 4 to 5 to get it to work.
1998 3500 4x4 5 speed reg cab dually
TST #10, ATS exhaust man, 5" turbo back exhaust twin 5" stacks, SB 13.5 clutch, BHAF, 75 hp injectors
Bluedually4x4 is offline   Reply With Quote
Old 11-04-2009, 09:53 AM   #3 (permalink)
If its cut off under the truck you will have to get enough adapters like a 3.5 to 6 if they make it if not do what Bluedually4x4 said and have to buy a few and put them together.
96 ext cab long bed Silencer Ring removed, No fuel plate, 4in turbo back, K&N Intake,...more to come
twarek04 is offline   Reply With Quote
Old 11-04-2009, 10:04 AM   #4 (permalink)
ynots57's Avatar
Bully Dog makes a exhaust pipe adaptor for 3 1/2 in. x 5 in
Buy a 5 in. to 6 in. tip for the end
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is online now   Reply With Quote
The Following User Says Thank You to ynots57 For This Useful Post:
hoytarchery7 (11-04-2009)
