| 94-98 Non-Powertrain Discussion of 94-98 Topics Not related to the Powertrain...NO ADVERTISING |
Broken Vacuum line??
Ok guy's I was changing my injectors yesterday and accidentally broke the connector that appears to be for the hvac system? Anyone have any ideas on how to repair this??
1995 CTD 4x4 100# Plate Full Forward Afc Foot mods set of 3k gov springs from Pdr,022 delivery valves, 5x0.14 injecters,Htb2 62/71/13ss, Goerand valve body, converter and various other trany goodies.Pyro,4 inch exhaust... |
#2 (permalink) |
More details. Exactly where did you break it at?
'96 Dodge 3500,KDP killed, boost-pyro-trans temp, not stock anymore '01 Dodge 2500 4X4, EC, LB, 6 speed, FP-pyro-boost, '97 Chevrolet Suburban, K1500, 4.10 gears |
#3 (permalink) |
If its a plastic line splice it with a small rubber hose.
98 12v,2wd twins,3:55,g56 6speed,elec fan clutch,100 hp sticks, 10 plate FF aFC fB,3gsk Valair ats,fluid damper,60#springs,o6 exhaust brake,High Idle,prime loc, 4"exh,piller mount |
#4 (permalink) |
I broke it directly under the cowl on the passenger side when trying to get an injector out. So those things are just twist apart couplings? I figured I would do exactly what you mentioned with the rubber line.
#5 (permalink) |
What do you think? This is wierd because normally I would simply just put a piece of ruber tubbing over ist and call it good! The only [problem is it changes sizes? Does anyone make anything to repair this sort of thing?? Is there some sort of fitting that I can use??
#6 (permalink) |
try napa online or maybe a copper tube and two hoses.? I like to walk around the junk yards and look for that kind of stuff.
#7 (permalink) |
NAPA sells fittings with multiple size fittings on each end. You trim off smaller sizes not needed until you get back to size you want to use. They can easily connect 1/8" to 1/4". Most have the packs of fittings hanging on a rack that spins round and round.
#8 (permalink) |
My 2 cents-Replace it with rubber hose. Plastic options are available in wrecking yards (my was free), but everytime I'm on that side of the engine, I still have to be careful. I will be replacing it with rubber soon-but for now, cruise and heater work fine.
97 3500 Xcab 5spd 4x4 Nearly Normal |
#9 (permalink) |
The thing that sucks is the plastic that goes under the dash is very thin and to be honest I have never seen vac. line that small? I will take a ride to advance and check there DIY section they should have somthing? The Guy at Napa either had nothing or simply could not be bothered??
