Old 10-23-2009, 07:12 PM   #1 (permalink)
huuhcummins09's Avatar
No overdrive!
OK just got my truck back from the shop and on the way home i noticed that it would not shift into overdrive!
Whats wrong????
96 2500 4x4 ReG! Cab!
0 Plate, Pump Tuning, lil Fuel, Lil air!
huuhcummins09 is offline   Reply With Quote
Old 10-23-2009, 10:21 PM   #2 (permalink)
LostSoul's Avatar
Check and make sure that they did not leave the plug out or damage a wire. You do not say what it was in for so that would be the easiest place to start.
1995 2500 4x4 Auto No mods as of yet, too much time modding the fun truck.
LostSoul is offline   Reply With Quote
Old 10-23-2009, 10:27 PM   #3 (permalink)
What plug?
I had a new pump put in.
Old 10-24-2009, 01:09 AM   #4 (permalink)
Bomaster238's Avatar
what pump? trans has to come out to put a new pump in
94 12valve 5 speed.5" single stack,AFE intake,Holset H1E, bosch 370s, TST #6, Schied Diesel DVs, HD valve springs, FASS150 A-meter Pyro and boost, boost elbow, KPD killed,16.5*, 550hp clutch on the way, leveling kit, 35s
Bomaster238 is offline   Reply With Quote
Old 10-24-2009, 01:15 AM   #5 (permalink)
rdix7991's Avatar
Injection Pump. Not brand new, but good.
This is huuhcummins09. I am on my brother's name.
2000 Ext.C SB 4x4,AD 150, 150HP injectors, 62/14/71, Georend
rdix7991 is offline   Reply With Quote
Old 10-24-2009, 01:54 PM   #6 (permalink)
Moderator
If they worked on the IP my bet is they didn't plug the TPS back in or it's out of adjustment.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Not stock
Old 10-24-2009, 06:12 PM   #7 (permalink)
Banned
Possibly a bad seal in the transmission.
LucasB is offline   Reply With Quote
Old 10-24-2009, 06:44 PM   #8 (permalink)
How do you adjust it?
Old 10-24-2009, 08:49 PM   #9 (permalink)
Moderator
TPS testing and adjustment
Bill
'95 2500 4wd auto
Not stock
Old 10-26-2009, 11:55 PM   #10 (permalink)
Did you check for any codes?
1995 2500 SLT Club 4x4, auto (DTT), 3.54, 3600 pound Elkhorn slide in camper (12'), AirLift air springs, Dana PowerLok™, . 193,000 miles
LandSharkWA is offline   Reply With Quote
Old 11-03-2009, 12:07 PM   #11 (permalink)
no how do I?
Old 11-03-2009, 08:27 PM   #12 (permalink)
Plug an OBDII scanner in or go to Auto Zone and let them scan if you don't have easier access to one. My bet is with Bill, something not right with TPS.
RPegram is online now   Reply With Quote
