| 94-98 Non-Powertrain Discussion of 94-98 Topics Not related to the Powertrain...NO ADVERTISING |
wiring issues
i have a problem and hpefully you guys might be able to help. when it rains and its dark i turn my lights on and my clearance lights, dash lights and tail lights all go out when the fuse blows. what might be causing the fuse to blow and where should i start looking for bad wires. thanks in adavance kyle
98 3/4 ton extended cab, 5 speed, cold air intake, star wheel cranked, fuel plate and AFC full forward, guages, straight piped. 305/70R16 mud terrains on Eagle Alloys. 2003 chevy buckets. |
#2 (permalink) |
If you remove the dash plate under the steering wheel it gives you access to all the wiring going into the firewall. You should start with the fuse and relay box on the fender and check the grounds
1994 4x4 Auto, 4.5 inch Lift, 35's, 160 pump, 4in Turbo back straight pipe, K&N FIPK 2, #0 plate, No AFC Influence, Overhauled with new body |
#3 (permalink) |
Super Moderator
![]() Join Date: Nov 2005
If it only happens when it rains I doubt the problem is under the dash. I'd start looking for a connector to one of the running or tail lights that's not plugged all the way together. Common problem is a trailer jack packed full of dirt that shorts out when it gets wet.
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Not stock |
#4 (permalink) |
does it only happen when it rains or every night you turn the lights on? first instinct should be to check your plugs. there are 2 under the cab on the drivers side going back to the tail lights, and of course your plugs on the front part of the fender pluging into a mounted unit.
