Truck vibrates when braking. - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 09-01-2009, 06:34 PM Thread Starter
1995 2500 ext cab diesel 4x4
The truck shakes badly when i apply the brakes. I have looked at the front tires while breaking and they shake side to side about 2 or 3 inches. The truck has some play in the steering and you can tell when I stop. Do the steering boxes wear out easy or does it have an adjustment. Let me know.
Thanks.
Dark-Horse-Diesel is offline
post #2 of 11 (permalink) Old 09-01-2009, 06:36 PM
Dont Upset The Hulk....
1badRam06's Avatar
Thanks.
Sounds like you may have some warped rotors.... IMO
2006 Ram 2500 QC, SB, Fun Truck, Far From Stock
2016 Ram 2500 CC, SB Sport Laramie All Show and No Go....
'06 Built for MJC 1984-2009
1badRam06 is offline
post #3 of 11 (permalink) Old 09-01-2009, 06:46 PM
CO President
ninerqb8's Avatar
Lot of things it could be but I would start with rotors since it shows when brakes are applied.
98 12 valve. 2014 EcoDiesel
Owner BH Diesel Service
ninerqb8 is offline
post #4 of 11 (permalink) Old 09-01-2009, 06:55 PM Thread Starter
I plan on doing that this weekend. How about the play in the steering wheel, or steering box adjustment. I may just replace it as well.
post #5 of 11 (permalink) Old 09-01-2009, 06:58 PM
1badRam06's Avatar
If the rotors are warped, the whole front end would shake, the worse the shake, the more warped they are. It may not have anything to do with the steering linkage, box or steering wheel.... IMO
post #6 of 11 (permalink) Old 09-01-2009, 07:02 PM Thread Starter
I just bought the truck about 2 weeks ago. I have plenty of bugs to work out and I am starting with this. Thanks for the help.
post #7 of 11 (permalink) Old 09-01-2009, 07:02 PM
CO President
ninerqb8's Avatar
If it were me doing it and I had it torn down enough to do rotors, I would be making sure it does not need ball joints, and front axle ujoints as well as wheel bearings as well. If it still wanders after all of that I would start looking at the track bar, then tie rods, then a box.
ninerqb8 is offline
post #8 of 11 (permalink) Old 09-01-2009, 07:06 PM
1badRam06's Avatar
If it shakes that bad, you might be better off just buying new rotors.
post #9 of 11 (permalink) Old 09-01-2009, 08:10 PM
Armchair Mechanic
colin91's Avatar
my truck would do that under braking after freeway driving and after i put in my Thuren track bar it went away
1996 2500 ECLB, NV4500, 4X4 (24 valve P Pump swap in progess)
Engine: Crowler Springs, Adj. Timing Gear at 21*, Haisley H11s, ARP Rod Bolts, DIY O-Ringed Block, DAP 3 Piece Manifold, Fluidampr, Southbend DD3250, 5" Turbo Back Exhaust + FTE Resonator
Air: S363XE (63/68/.8) + The Ol' Trusty BHAF
Fuel: 215HP P7100, Infinite Performance 6x11 VCO, Scheid Conversion Lines, PDD 055 DVs, AirDog, Dual Feed, AFC Live Stage 1, 4K GSK
Suspension (So Far): Thuren 3" Coils, Thuren Torsion Sway Bar, Thuren Track Bar, DOR Shackle Flip, DOR Extreme Bent Long Arms, Fox 2.0 IFPs, 35s on H2s
colin91 is offline
post #10 of 11 (permalink) Old 09-01-2009, 08:48 PM
MX26's Avatar
Agreed. I'd start with the rotors & inspect all of your balljoints & bushings while you've got it down. Before you tear it down, get a buddy or lady friend to sit in the truck, running, and turn your steering wheel from side to side. You should be able to notice any play in your trackbar's joints.. Do that before you put it on the jackstands; won't work without the truck weight on the suspension. If you have much play, you could either replace the entire bar, or I'd advise you to do a Luke's Link setup.
And to answer your question, how much slack do you have in the wheel? Your steering gearbox has a slack adjustment built in. It should be an allenhead type bolt with a jam nut on it. You can try to do some adjustment there, but keep in mind that it doesn't take much to make a huge difference. If you get it too tight, your truck will not seek center.
David
24 + 6.7 < 12
Originally Posted by dad2bike View Post
I went for about 20ft after the hit and felt fluid down my chin.
MX26 is offline
post #11 of 11 (permalink) Old 09-01-2009, 09:15 PM
If it's wobbling as much as you say the wheel bearings are probably shot.
Your rotors may be just fine.
If the rotors are warped it's not worth it turning them, buy new ones.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
