1998 12V Cummins Lift Pump problems - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 07-30-2009, 11:55 PM Thread Starter
MattRoberts's Avatar
Hey Fellas,
I have a '98 3/4 ton ext. cab 4wd 12v Cummins with 217,000 on it and have found out by a "cummins specialist" that the lift pump is bad and that the "fuel pre-heater" looks to be "sucking air" and recommended I bypass it. He said the "Delphi" lift pumps are not very good and would only last a couple of years, and a good one would cost about $250 or so. (He'd fix the lift pump problem for $550, parts and labor)...as I'm laid off that sounds high??? I also asked him if advancing the timing to 16* would gain me better power and MPG's...The answer was yes, but the price to do all of the above then went up to $1000....Is this guy pullin' my chain or not? What brand of lift pump should I replace mine with if the Delphi is not that great?
Basically I want to do all of the above as economically as I can due to being unemployed, but also want to do it right the first time,,,,Suggestions?????????
Matt Roberts
Chelsea,OK
MattRoberts is offline
post #2 of 9 (permalink) Old 07-31-2009, 12:00 AM
justadonor's Avatar
basically, your "mechanic" is full of s*it, the mechanical lift pumps are perfectly fine on the 12 valve, if you want to upgrade get an airdog or a fass pump, about the fuel heater, i've never heard of those sucking air, but i could be wrong im sure someone will answer your question better
2002 LB7 duramax, EFI live, airdog II 165, FBD 5" exhaust
justadonor is offline
post #3 of 9 (permalink) Old 07-31-2009, 12:16 AM
Ford_cummins83's Avatar
Yeah x2, dont talk to that guy anymore.. dont know how good you are with tools but putting on a lift pump isn't too bad at all, it is right under your fuel filter with 2 bolts into the side of the block, i just got trough pricing a new lift pump which runs 146 at vato zone, you may be able to use a 93 but im not sure if there's a difference but they are cheaper.. You could get a fass for less then what your mechanic wants to charge you lol
'11 drw, 6.7.. Black maxx/mcc.. 5" tbe, intake, fully deleted and some led/hid goodies
Ford_cummins83 is offline
post #4 of 9 (permalink) Old 07-31-2009, 02:26 AM
calebmcclellan's Avatar
iTrader Score: -1 reviews
what is the problem you are having? yes the fuel heaters are junk and can suck air and cause problems. maybe just bypass it, and then your lift pump will be working fine, then just send me the $500 lol
86 C/20 w/94 12v 420k miles
calebmcclellan is offline
post #5 of 9 (permalink) Old 07-31-2009, 04:00 AM
12VEG's Avatar
Essentially, your mechanic is smoking crack. Bad crack.
New lift pumps can be easily found for $90, ditto to the fact that it's an easy replacement procedure, it took me about an hour which is probably longer than it should, but I removed the starter to make access easier.
Read this
http://www.cumminsforum.com/forum/94...m-writeup.html
and follow the steps for bypassing the fuel preheater, it's a good idea, they can suck air for sure. Also check all of your fuel lines for cracks around the ends, you could be having an air leak from there.
Don't talk to that guy anymore, he's gettin' over on you.
Newbie Questions? FAQ's? Read this first please:
1997 2500 SCLB NV4500 4x4 - 5x.012 VCO's, No Plate, Modded and Tuned AFC, 4K GSK/60# VS, 2095 Plug, 16 Timing, 4" TBE, K&N Intake, Isspro EV Gauges, South Bend SDD3250, BFG All-Terrains, Bilstein 5100's, KDP Tabbed, Steering Box Stabilizer, 40 Gal. Veggie Oil System, B100 & WVO burner!
12VEG is offline
post #6 of 9 (permalink) Old 08-01-2009, 12:49 AM
redneckcustoms13's Avatar
another common problem is the screen in the lift pump gets clogged with trash. just simply remove it blow it off with carb cleaner and poke it back in there. its fixed 2 that we had the very same problem with
redneckcustoms13 is offline
The Following User Says Thank You to redneckcustoms13 For This Useful Post:
wheeler_423 (03-02-2017)
post #7 of 9 (permalink) Old 08-01-2009, 01:03 AM
Generally the lift pumps are strong and reliable, however they can have problems. The first and foremost thing you should do is install a fuel pressure gauge. That will tell you everything. Sometimes the "O" ring on the plunger can go bad. 10 cents at the hardware store will fix it. If you do have to remove the LP, replace the bolts with studs. You will never get it back on, especially if you are still using the fuel heater. If you remove the lift pump, make sure the internal rod does not drop into the engine. Major hassle if it does. The fuel heater can pull air, usually through the electric plug on the bottom. Smear a bunch of dielectric grease all over it. If the problem stops, you know the cause. The grease is a temporary fix. Concerning your mechanic, find another one.
96 reg cab, 5sp long bed 4x4: 4GSK, pump and AFC altered, AFE filter, gasket matched and ported exhaust manifold, Fluidamper, 4" exhaust, gauges, 5th gear upgrade, KDP KO'ed, Hamilton cam, Southbend Con OFE, Bosch injectors, Dynatrac axles and hubs (don't go there, they don't stand by their product), airplane landing lights, Dana Powerlok's front & rear, front truss, F&R skid plates, runs on WVO.
Baja is offline
post #8 of 9 (permalink) Old 08-01-2009, 11:23 AM
Think you must be talking about the screen in the fuel heater, there isn't one in the lift pump.
Go here> Fuel Pre-Filter Cleaning on Ram/Cummins
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #9 of 9 (permalink) Old 08-01-2009, 12:27 PM
yep, sorry i wasnt very clear with my instructions
