Old 07-20-2009, 12:26 AM   #25 (permalink)
12valve4life's Avatar
Ok, so mirrors off VP trucks will or will not fit on a pre 98?
1995 Red CTD Reg Cab 2WD auto - #0 plate/BHAF/WasteGate Plugged/Exhaust/8 inch tip/leveled/Chrome 20's & 33's/Black Halo twin projector headlights
12valve4life is offline   Reply With Quote
Old 07-20-2009, 12:27 AM   #26 (permalink)
cmns2500's Avatar
well, considering they didn't go to plastic mirrors till '00, yeah, they will fit, both the metal and plastic ones...
J 02 5 speed w/ not much stuff i post a lot...DEAL WITH IT
Old 07-20-2009, 12:58 AM   #27 (permalink)
lly
lly's Avatar
Originally Posted by MMStar923 View Post
mopar ones are gonna run you about $250 for manual ones. i just bought a set for $299 for heated/ powered mopar ones. dont get aftermarkets though, i hear the mirror rattles like hell
Yes I got the kool veiw an one broke right after I bought it an it was just out of the 30 days,an you cant see anything when there flipped out cause they shake so damn bad
95 12V NV45 rclb 617HP
05 Duramax LLY,473hp
lly is offline   Reply With Quote
Old 07-20-2009, 12:37 PM   #28 (permalink)
Well hell if id known that i wouldnt have made this post. Looks im goin to the junkyard.
Old 07-20-2009, 02:24 PM   #29 (permalink)
They changed mirrors in 98.
And you can make power/heated with third gen heads, and second gen bases.
97 4x4 extended cab
Valair Inc clutch
displacedtexan is offline   Reply With Quote
Old 07-20-2009, 02:28 PM   #30 (permalink)
cmns2500's Avatar
yup.....
Factory Power Tow Mirror Swap - 3rd on a 2nd Gen
and, lemme rephrase my comment, they didn't change to the plastic tow mirrors till '00...
Old 07-20-2009, 02:34 PM   #31 (permalink)
yup.....
Gotcha! I was thinking you meant something else
97 4x4 extended cab
Valair Inc clutch
Old 07-22-2009, 01:11 PM   #32 (permalink)
i thought you couldnt get power tow mirrors for the 2nd gen trucks. if you can why not from dodge. mine came from dealer for 250
f pintar is offline   Reply With Quote
Old 07-22-2009, 01:16 PM   #33 (permalink)
kiohio's Avatar
You can get the powered mirrors, but they are the bent lollipop style.
Most are wanting the 3rd gen style mirror with a 2nd gen base.
Heated and Power.
I know that's what I want.
KO
'96 4x4 EC Goerend-Triple Disc TC-Auto-4.10's-305/70 Terra Grapplers-909's-5" Grand Rock to da bumpa-Custom Injectors-HTBG 14cm-4K-GSK -19*-Fire Ringed-Titanium crap here and there-ATS 3pc-
If I have something for sale it's always "First come, First serve", been burnt too many times...Sorry.
kiohio is offline   Reply With Quote
Old 07-22-2009, 01:27 PM   #34 (permalink)
cmns2500's Avatar
you can't get em from Mopar, for whatever stupid reason, Mopar only makes manual ones...
Old 07-24-2009, 01:19 PM   #35 (permalink)
SmokeN 12 ValvE's Avatar
what would a good set of used mopar manual flip up's be worth?
James
96 1500 RCSB 4x4 12v in the works
SmokeN 12 ValvE is offline   Reply With Quote
Old 07-24-2009, 01:41 PM   #36 (permalink)
cmns2500's Avatar
around 150 bucks or so, it would def be worth less than the kool view electric ones.....
