Old 07-02-2009, 10:53 PM   #1 (permalink)
no cruise control light
my cruise does not work the light on the button does not come on, i checked all vac lines all good same with electrical connections, took switch apart everything is making contact when buttons are pushed.Everything else works fine. Is there a hidden fuse some where or a relay of some sort. These four hour drives really suck with no cruise
97 3500 auto 4x4 with shift kit and billet tc, no fuel plate, cold air intake, hollowed out cat to 4" straight pipe with down spout before rear axle, afc arm removed, silencer ring removed,boost elbow, autometer gauges
tbest is offline   Reply With Quote
Old 07-03-2009, 09:58 PM   #2 (permalink)
it is probably the switch, i just replaced mine check to see if your getting power out of the switch take a test light and ground it out, and find the hot wire, then go to the other wire and try to turn it on and see if your getting power out of the switch, i got my switch for like 30 bucks
koolrcr531 is offline   Reply With Quote
Old 07-04-2009, 01:18 AM   #3 (permalink)
Kronic_187's Avatar
my light doesnèt work... but the switch does...
96 2500 CC LB 4x4: BD 47RE/Flexplate/TC, 4" MBRP, S362/65/12, BHAF/K&N tube, #10, AFC tweakd, 4gsk, 60# springs,125ft/lbs. headbolts, 16°, Gauges, Lift'd 6"/Ladder bars, Dana 80 w/ disks
Kronic_187 is offline   Reply With Quote
Old 07-04-2009, 04:59 AM   #4 (permalink)
ykdave's Avatar
their is a fuse for the cruise (IIRC its tied in with about 50 other things...)
97 Ram 2500 / 5.9ctd /NV4500/241DHD
Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
ykdave is offline   Reply With Quote
Old 07-06-2009, 10:45 PM   #5 (permalink)
where is this fuse, i checked the plug goin to the switch and could not get any power
