Need Battery Suggestions! - Dodge Cummins Diesel Forum
post #1 of 27 (permalink) Old 02-11-2007, 09:51 PM Thread Starter
Hello,
When my truck isn't plugged in and it's real cold out 0-20* F, especially when it sits all day or overnight, the batteries don't seem to have enough juice to turn the motor over. Defintitely related is the fact that my gauges are hooked up to the 12V outlet in the dash and I need to relocate that wire. But, when it's above 30 degrees I have no problem at all starting the truck if it sits for a while. Does having my gauges hooked up to the 12V outlet draw that much power when the truck is off and would it effect cold starting that much if the block isn't plugged in.
More than likely, my batteries need to be replaced though. I was hoping to get a few suggestions for batteries for my 98 12v. I'd like something that will have the cold cranking power for temps to 0*.
Thanks.
1998 Dodge RAM 2500, 12 V, Club Cab, LB, BHAF, #6FP, 3GSK, ISSPRO Gauges, 4" SS Exhaust, Bilsteins, tabbed KDP, Goerend Transmission, 240K
Last edited by objectmaker; 02-11-2007 at 10:59 PM. Reason: needed to add more info
objectmaker is offline
post #2 of 27 (permalink) Old 02-11-2007, 11:07 PM
Looking for a truck again
oestreich84's Avatar
Something that might be easier and cheaper is switching to synthetic oil when it gets cold. I know my truck starts much easier when using it.
*SOLD*98.5 2500 regular cab, long box, 4x4, 24 valve, 5 speed, 5 inch straight pipe, autometer cobalt series boost and pyro gauges, isspro fuel pressure gauge, fram boost intake, jammer 3's , edge comp with MAP unplugged, Holley Blue inline fuel pump, 285/75/16 Mastercraft Courser CT's, high flow banjos, tinted windows, Alpine head unit, Infinity 6x9's in doors, and a couple other go fast secrets! Now driving a 01 dakota
oestreich84 is offline
post #3 of 27 (permalink) Old 02-12-2007, 01:14 AM
Synthetic oil helps but if your batteries are junk I would suggest getting a pair of 1100CCA Interstate batteries. I have had ones that were froze solid and thawed out that worked just find for another 2 years or so. Impressive for lead plate battery.
'01 QC dually 4x4 -silver-
Banks power elbow
4" exhaust with 5" stacks
80hp BD injectors
Edge EZ box
Moded air box
Boost fooler
Pyro and Boost gauges
:thumbsup
lbeenken is offline
post #4 of 27 (permalink) Old 02-12-2007, 02:37 AM
RDyson's Avatar
There was a battery thread a while back and a lot of people were very satisfied with the Wal Mart batteries. Made by a good company and cheaper than the big names.
Randy
2014 QC Laramie
Sold--03 SO/Auto, QC/4X4, TST/Smarty/Puck, Boost/Fuel/Pyro/Rail, SPS-62, Goerend, Airdog, Arson Kit, Wicked 50's, ARP, 613/1171, 13.16@108.2
RDyson is offline
post #5 of 27 (permalink) Old 02-12-2007, 04:06 AM
My Wal-mart batteries are 6 years old and still cranking.
racknrider is offline
post #6 of 27 (permalink) Old 02-12-2007, 05:38 PM
Optima batterys are the answer,, Best battery I have ever owned, and being they are completely sealed no need to ever clean the connections again. I will say they are expensive, but they are the best.
96 Dodge 2500 Extcab longbox 2wd Automatic by Goerend Bros,,,, Pyro, Boost and Tran temp, 100 Plate, DDP Stage 2 injectors, GWK , BHAF 4 in exhaust
Outlawstorm is offline
post #7 of 27 (permalink) Old 02-12-2007, 06:25 PM
64cowboy's Avatar
Randy
I've had a pair of the Yellow Dura Maxx Batteries from Walmart for the past 6 years and are still going strong. 1000 CCA at 32* and drop to 900 CCA at 0*
I think these are warranted for 9 years, good battery for the price IMHO
Never mind the Mules, Just load the Wagon!:
1997 2500 4x4 Auto, 4.10 Reg. cab Long box. BHAF, Silencer ring M.I.A.Dowel Pin Killed Phantom Triple gauges, #5 Plate Slid some, Star wheel cranked.
64cowboy is offline
post #8 of 27 (permalink) Old 02-12-2007, 09:29 PM Thread Starter
Thanks everyone for your advice. Went to wallyworld and was surprised how cheap the batteries were there and am happy to hear that it's actually a good product for the price. So outlawstorm, what do you consider expensive for the Optima batteries?
post #9 of 27 (permalink) Old 02-12-2007, 09:41 PM
GottSoot's Avatar
i just put in my optima yellow tops, and i love em! they were about 168 a piece. so yeah kinda spendy. but i figure that they will last, are completly sealed, and will completly recharge if you drain them ALL the way. But ive also had good luck with the EverStart MAXX wal mart brand.
Billings Mt. Home of the Dirtymax!! 9.46 149MPH
GottSoot is offline
post #10 of 27 (permalink) Old 02-12-2007, 10:16 PM
fight4yourrights's Avatar
Be sure your terminals aren't loose
Our engine shake
2008 Piece of Crapola. Gets 2,000 miles per turbo. Does 23 mph at full throttle. Why did I trade in my 2001?
fight4yourrights is offline
post #11 of 27 (permalink) Old 02-12-2007, 11:14 PM
Banned
I think an important thing to consider is getting a sealed battery. Conventional type batteries will leak acid and destroy the inside of your fenders. Not only that, due to the beating these trucks take on the front end, the batteries get shook to death - again, a conventional battery isnt always the best choice here. Cheapest isnt always the best. Optima, or better yet , Oddessy batteries are a great way to go.
Ever seen the Odessys?:
Odessy Batteries
Dr. Evil is offline
post #12 of 27 (permalink) Old 02-13-2007, 01:03 PM Thread Starter
Yowza! I called the local supplier for those Odessy batteries and they want
$270 a piece for them. The Optima were much less, but still pricey at $164 a piece. Wallyworld wants $72. Looks like I'll find something in between, though
the Optimas are tempting. Thanks again for all the advice.
