cps sensor? - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 01-25-2009, 07:42 PM Thread Starter
cummins96's Avatar
cps sensor?
do these sensors tend to fail? the reason i ask is last time my truck was running i did the harmonic balance seal. and when i put it back together i fired up the truck and noticed my tach was not workin well my truck has been apart for some time and its time to start puttin it back together and figured id ask what you guys think it could be? something else i should check?
thanks
2011 Ram 3500 crew cab. Laramie. 5" straight exhaust. mini max/overdrive software. afe cold air kit. Espar D5. h&s egr/cooler delete.ARP studs, fass titanium 150gph, h&s intake and boost tube. 8" BDS long arm kit. amp running boards. 37 cooper stt tires on 20" fuel rims. halo lights running 6000k HID's. revmax 850 transmission. 4.56 gears. Custom mcc tuning (draconian diesel)
cummins96 is offline
post #2 of 3 (permalink) Old 01-25-2009, 08:59 PM
Your truck doesn't have a CPS, that's a 24 valve thing.
It does have an engine speed sensor (ESS) that do fail.
More often the problem is cut wires or improper gap.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 3 (permalink) Old 01-25-2009, 09:01 PM
AlGores worst nightmare
Racer9's Avatar
Make sure it's plugged in, and check the gap. About a playing card thickness from the balancer.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar, DSS, HD steering.
Motor; BHAF, #100 fuel plate, 5X.012 90hp injectors, Pacbrake 4kGSK, Loose starwheel. 306hp/743tq before injectors.
Exhaust; Schwitzer S300G, 4" downpipe, single 5" turnout stack.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline
