Old 01-07-2009, 01:42 PM   #1 (permalink)
M K
Headlight high beam ???
When I turn on the high beams should the low beam filament be on or off ? Right now the low beam filament turns off when the high beam filament is on , it seems to me that both HI & LO should be on when the bright light are on . If both should be on how would I fix the problem is there a relay or something ?
97 - 2500 club cab 8ft box , 2 wheel drive auto trans 4:10 rear end , BHAF,heat shield & AFE intake tube, Autometer boost, pyro ,trans temp guages , stock afc plate moved forward , AFE 4" stainless turbo back exhaust , Alpha bed liner ,repainted white
M K is offline   Reply With Quote
Old 01-07-2009, 03:01 PM   #2 (permalink)
Moderator
Nothing is wrong.
They don't both come at the same time unless you modify them to do otherwise.
Some people do the mod with a simple relay hook up.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Not stock
illflem is online now   Reply With Quote
Old 01-07-2009, 03:45 PM   #3 (permalink)
AlGores worst nightmare
Racer9's Avatar
That's normal.
'96 2500, CTD, 4X4 flatbed, Isspro gauges, Skyjacker D-25's, ThurenFab track bar.
Motor; BHAF, #100 fuel plate, Shimmed gov springs, Loose starwheel. 306hp/743tq
Exhaust; Schwitzer S300G, 4" downpipe, 5" turnout stacks.
Trans; Dunrite VB/TC, Intelligent Engineering billet input shaft, Burt Brown rebuild/upgrade.
Racer9 is offline   Reply With Quote
Old 01-07-2009, 04:07 PM   #4 (permalink)
txpig's Avatar
Yea it's normal. Crapy enginering and design if ya ask me. I upgraded my lights with a Bright Box. It keeps the low beams on when you turn on the high beams. I have one on my 2008 and it really made a diffrence!
BRITE BOX - ('94-'98 DODGE) WITH FOG LIGHT CONTROL-Dodge Cummins and Ford Power Stroke Diesel Truck Accessories - Geno's Garage
2008 3500, QC, SB, 4X4 Laramie, 68RFE, XRT, MP-8, 5" TBE, MPH trans tune, EGR/BlueTec Badge MIA, Volant Power-Core CAI, Raptor 150,Amsoil By-Pass, Mag-Hytec Trans & Rear Diff, Lorenz Bilstein 5100 System, PSC Steering Brace, B&W GN, Ride Rite bags
txpig is offline   Reply With Quote
Old 01-07-2009, 04:22 PM   #5 (permalink)
Moderator
$119 for a Bright Box!!!
You can do the same thing with a $10 relay and a couple of crimp connectors.
Bill
'95 2500 4wd auto
Not stock
Old 03-03-2009, 05:57 PM   #6 (permalink)
StraightSix's Avatar
how do you do this with the relay? dose anyone have a write up on that procedure?
2007 5.9 mega cab 4x4 dually six spd. 4" dual exhaust, air intake, gooseneck, airbags, and onboard air. (MUCH MORE TO COME)
StraightSix is offline   Reply With Quote
Old 03-03-2009, 08:51 PM   #7 (permalink)
Moderator
Figure out which wires are hi and low behind your drivers side headlight with a meter or test light.
Tap (tee) into each wire with a new wire, a Scotch-Loc connector works great.
Connect the hi wire to the trigger side (pin 85 on most relays).
Connect the low to switched side of the relay (pin 87).
Put 12+ on the other switched side of the relay (pin 87A). Use a inline 20 amp fuse and grab the power from the driver's side battery terminal.
Ground the other trigger terminal (pin 86).
Relay can be attached to the front side of the battery box.
You're done, beauty of this modification is if anything goes wrong if reverts back to the normal set up.
Bill
'95 2500 4wd auto
Not stock
