Fuel Shut off Solenoid (FSS) - Dodge Cummins Diesel Forum
94-98 Engine Tech articles dealing with the 2nd gen 12V engine
post #1 of 6 (permalink) Old 01-28-2013, 11:29 PM Thread Starter
The 10th Man
Cowboy303's Avatar
The FSS (Fuel Shut off Solenoid) is the way our trucks can turn on and off the engine. First off it is one of the most needlessly replaced parts on these engines. The most common way to kill them is the starter to stick on giving the "Pull" wire power for a long period of time, which produces a lot of heat inside the FSS, and it burns up, you most likely don't need to replace it unless it looks burnt. If your FSS is not working correctly then it's most likely your wiring or a dirty shaft.
When the FSS lever is down, the Injector lines will not receive ANY fuel.
Shut off solenoid location:
And this is the arm that needs to be up to let fuel in the injector lines, this is under the shut off solenoid. The rubber boot and the plunger coming out of the boot are part of the shut off solenoid. the lever the shut off solenoid pulls up is part of the Injector Pump
Here's a wiring diagram: (I would recommend clicking the bar on top the image to view it full size)
There are 3 wires going to the FSS, Ground, Hold and Pull.
"Ground" wire, truck side is black with a orange stripe, FSS side is all black, it is connected to ground all the time.
"Hold" wire, truck side is small light green with a black stripe, FSS side is normal sized Red wire, the Hold coil (an electromagnet) gets power when the key is in the run position. Since the plunger is spring loaded to push the lever down (turn off engine). The Hold coil Does not have enough power to pull the plunger up (compress the spring), and only has enough power to keep the plunger up, once it's all the way up (keep spring compressed). So in order for the hold wire to hold the lever up, the Pull coil must bring the plunger all the way up first.
"Pull" wire, truck side is Red, FSS side is White, the Pull coil (an electromagnet) gets power only when the starter is engaged. it has plenty of power to pull up the lever (compress the spring), but if it's kept on to long it will create a lot of heat and will burn up the FSS. the Power wire gets power from the FSS relay(Part# SS70A), the relay gets its signal power from the small wire coming off the starter.
If you're ever on the road and it shuts off or won't start then you should be able to tie that lever up with a bungee cord, some wire, rope or something. that lever needs to be up for the truck to start.
You can test the FSS by trying to start the truck and then leaving the key in the "Run" position, feel under the FSS to make sure it's all the way up, if it's all the way up then it shouldn't be your problem, unless you have a lack of power problem then the lever might not be going all the way up then you can test it by going HERE and check that the arm is really going all the way up, if it isn't it could be that your shaft is dirty or rusted or simply it might not be adjusted correctly.
- '96 2500 ECLB
3.54's, Cooper AT3 265's, Head Securing Devices @ 130ftlb, Custom GSK,
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
Cowboy303 is offline
The Following 9 Users Say Thank You to Cowboy303 For This Useful Post:
candohome (07-27-2016), CTD2500 (10-27-2013), DanG144 (12-10-2015), Dude1 (04-25-2014), Keiols486 (01-11-2015), plumbertom (02-17-2015), rebar (10-18-2015), RickClovis (02-21-2014), WetWilly12 (03-28-2016)
post #2 of 6 (permalink) Old 01-29-2013, 12:10 AM Thread Starter
The 10th Man
Cowboy303's Avatar
And for people that would like a little more info:
here's a picture of of the rack when the FSS is fully down and the throtal is at idle, notice that the arm compresses the spring to bring the rack back to the shutoff position, yet the fueling arm is still the same spot (refer to the next 2 pics):
And here's a picture of the rack at idle with the FSS lever all the way up:
notice that the fueling arm (one that touches the AFC foot and fuel plate) does not move because it is up against the low idle screw. And see how if the FSS lever is not all the way up it will restricted rack travel. That is why you need to make sure that the arm is adjusted correctly to allow full fueling.
Here's a picture of the FSS lever all the way up at WOT with out a Mack plug:
With the Mack plug installed there is 0.2127" of gap between the lever and where it hits the rack.
With the Mack plug not installed there is a 0.11" gap.
- '96 2500 ECLB
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
The Following 3 Users Say Thank You to Cowboy303 For This Useful Post:
CTD2500 (10-27-2013), illflem (01-29-2013), Quest (01-29-2013)
post #3 of 6 (permalink) Old 01-31-2013, 02:08 AM Thread Starter
The 10th Man
Cowboy303's Avatar
Common problems and there fixes
Problems that will cause "No start":
The blue fusible link is a common problem (Diagram HERE), it fuses the "Pull" wire going to the FSS. On the 94-97 it is located on the drivers side positive battery terminal. it often gets corroded at the connector or inside the insulation, go to your auto parts store and ask for a "14 ga fusible link" (it might not be blue but that does not matter there both the same) then cut the old one off and use a crimp connector to install the new one.
(not sure about 98, if you have info please PM me, I will try to get the info ASAP)
Pull Relay is located on the fire wall in picture below (it's the bigger one), Part# SS70A, this relay is what gives power to the "Pull" wire to lift the lever when the starter is engaged. Here's a good place to get the Relay LarryBs.com Dodge
Rotted Boot, the Boot will often rot off and let dirt on the shaft which will cause it to get stuck, To clean it and replace the boot, simple remove it from the truck. Cut any zip ties off that may be holding the old boot on. Use a rag and clean off the plunger and the bore. When reinstalling, I used a little grease, just make sure not to use to much as it might make an air tight seal and not let the plunger lock up, causing the truck to shut off once you let off the starter. If your boot is rotted then it would be best to replace it, Here's a good place to get a new boot LarryBs.com Dodge
A how-to video >
Truck Starts and shuts off
Connections Check the FSS connection and make sure it's not corroded. and check to see what all things you loose when the truck shuts off, gages/lights/radio/etc. The hold wire is fed by the 'green w/black stripe' wire. that's the same wire that powers a bunch of other things. so that's probably your problem if you loose gauges, radio, ect. Refer to the wiring diagram above.
FSS Out of adjustment. This isn't very likely unless you just replaced or monkeyed with the FSS. In which case adjust it as needed Fuel Shut off Solenoid (FSS) . Just like with the rotted boot, if the plunger can't go up all the way because the rod connected to the lever on the Injection pump is adjusted to short, the hold coil will not be able to keep the plunger up, and the truck will shut off once you let off the starter.
Low power/will not rev as high
Fuel shut off lever not coming up all the way
There's two things that can happen, A) the FSS can get dirty so the shaft doesn't come up all the way (refer to "rotted boot" just a little ways up). B) The FSS is not adjusted correctly, Go HERE to see how to adjust it, if it's not adjusted correctly, adjust the FSS shaft as necessary
Won't Shut-Off, or Shut-Off is delayed.
Check 'Rotted Boot' above
Missing Woodruff Key on FSS Shaft
If the key is missing, the lever will just spin on the shaft and may not allow the engine to shutdown, or just delay shutdown. Once started, the engine may act normal, or be low on power. After uninstalling the FSS, You can loosen bolt 'C' in THIS picture to slide the lever off the shaft and insure the keyway is installed as it should be.
HERE'S a picture of where the key should be.
The Woodruff key part number is Cummins 3920924 or Mopar 04761316. CumminsForum member thecheese429 reported that a 2mm X 3.7mm woodruff key he found at ACE hardware was also the correct size, and could be had for a couple bucks.
Notice I didn't say anything about replacing the FSS its self, there's a reason for that. it almost never fails and if it does you can normally tell by looking at it that it is burnt. in which case you can get one from here LarryBs.com Dodge
- '96 2500 ECLB
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
The Following 4 Users Say Thank You to Cowboy303 For This Useful Post:
CTD2500 (10-27-2013), Dude1 (04-25-2014), plumbertom (02-17-2015), RickClovis (02-21-2014)
post #4 of 6 (permalink) Old 02-06-2013, 11:45 PM Thread Starter
The 10th Man
Cowboy303's Avatar
How to Adjust the FSS
  1. First here are the tools I used, your truck may be different so use what works best for you:
    1. 3/8" ratchet w/5/16" socket and 9" extension
    2. 1/4" ratchet w/5/16" socket
    3. 10mm open-end box-end wrench
    4. Needle nose pliers
  2. Now loosen up these two bolts that hold on the FSS, take them out about 1/4" or until the end of the bolt is flush with the plate (we want to loosen them but don't want them to fall out, you will know why in a bit).
  3. Working on it...
  4. OK we loosened the bolts up, and now have some gap, the arm is spring-loaded so it will want to push the FSS body up.
  5. Now turn on the key to the "run" position, Go out to the FSS and and push down on the main part to close the gap and lift up on the lever until it clicks up.
  6. The FSS clicks up when the ARM is all the way up, so what you want to do is make sure the Lever is all the way up when the arm clicks up. So sense the bolts holding down the FSS body are loose try lifting on the FSS body to see how high you can lift it, if you can lift it more then 1/8" then the lever is not coming up enough and is limiting fueling on the top end(go here know how it works).
    To adjust:
  7. Loosen up the lock/jam nut on the shaft,
    Before:
    After:
  8. First take out your cotter pin on the shaft,
  9. Slide the end of the FSS arm off the shaft, before you do, either turn off the key or unplug the FSS so the arm falls down (every time you turn on the key the grid heater will cycle if it's under 60* out),
  10. And spin it to adjust the height of the lever when the FSS arm is fully up (clicked up),
    How much you adjust it is based on the results you had on step 6, then repeat steps 7-10 until you like how the test performed in step 6 goes.
    Put back together
  11. Slip the arm Back on the shaft, before you try, either turn off the key or unplug the FSS (every time you turn on the key the grid heater will cycle if it's under 60* out).
  12. Put the cotter pin in,
  13. Tighten the lock nut over the shaft,
    Tighten the bolts that hold on the FSS body to the bracket,
    Wolla!!! DONE
If there's something I didn't explain very well or you would like me to add please PM me. Thank you!
- '96 2500 ECLB
, #10 plate,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace,
, couple gauges.
The Following 15 Users Say Thank You to Cowboy303 For This Useful Post:
83Jim (10-29-2013), CTD2500 (10-27-2013), DanG144 (12-10-2015), Dude1 (04-25-2014), hookit (11-14-2015), illflem (10-11-2013), jmacjgm (03-21-2014), LongBlackRam (08-29-2015), necred (04-26-2015), prime (12-02-2014), sn0man (02-07-2013), spankey0069 (11-11-2013), TEX (01-18-2014), texascrewser (08-21-2014), W900L (01-25-2014)
post #5 of 6 (permalink) Old 09-30-2014, 11:39 AM
I resently had the FSS relay go out on my 97. So I desided to take it apart, and see what was in it!
Taking it apart is simple, there are just four barbs that hold the cover on, so to get in I simply pushed 4 flat screw drivers on all four sides and pulled on one of the big spade terminals with needle nose pliers.
Once in, it wasn't hard to find the issue, RUST!
From here, we remove the spring sitting on the top in the picture above, and bend the tab in the next 2 pictures picture.
Now we can look at the contacts, mine have seen a better day, but still wern't to bad.
After some steel-wool and a wire brush.
When I put it all back together, I sprayed some "battery terminal protector" in the relay before installing the cover. Hopfully that will help it last longer. When putting on the cover, make sure to install it in the right position, refer to the first pic of this post for orientation.
Through it back in the truck and it's worked the couple dozen times so far, we'll see how many miles I can get out of it.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
The Following 9 Users Say Thank You to illflem For This Useful Post:
97Rebel (03-21-2015), Cowboy303 (09-30-2014), DanG144 (12-10-2015), hookit (11-14-2015), LongBlackRam (08-29-2015), necred (04-26-2015), plumbertom (02-17-2015), rebar (10-18-2015), ROCKYTOPCUMMINS (06-20-2015)
post #6 of 6 (permalink) Old 01-27-2016, 11:21 AM
The Uppity 12v Guy
dauntless89's Avatar
test/
'95 2500 ECLB 4x4, 320k and counting.
with
, 20į,
, and lots of other cool stuff.
<<< Check out my garage for details and links to my write-ups.
In Progress:
Back Burner:
dauntless89 is offline
