NP241 DLD Rebuild w/Pics - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 94-98 Tech Articles > 94-98 Drivetrain (except engine)
94-98 Drivetrain (except engine) Tech articles dealing with the transmission, transfer case, axles, driveshafts, etc.
Old 11-12-2011, 10:30 AM   #1 (permalink)
3.9 islander's Avatar
Alright so i am half way through rebuilding my transfer case and i wanted to put some more knowledge into this great forum.
So i guess first i will describe the symptoms-
1) In only forth gear, the drivetrain would make a real bad humming/grinding noise.
2) T case popping out of 2HI and 4HI into neutral at speeds over 30 mph.
3) Noise sounding like a monkey throwing tiny wrenches into the gears in 4HI and 4LO.
4) Worse that it got, would not go over 50 mph in 5th, felt like something was holding it back.
Causes of the problems-
1) Destroyed input bearing, outer race was in three pieces, the holding cage was non-existent, and the balls were very off round.
2) Due to bad input bearing, the teeth on the range and the back inside of the input shaft were worn at an angle causing it to slide out of HI range.
3) Someone did not put the syncro snap ring in holding the syncro studs in place. Found the ring at the back of the case. A stud fell out and got smushed in the chain, ruining the teeth causing the clicking noise.
4) Never found an actual cause, just assuming it was a combination of everything!!
Rebuild Time
Tear Down-
I took the case out for the ease of rebuilding it in my dorm room and not in the cold VT weather. So to do this, remove driveshafts and shift linkage and vacuum plug, get it all out of the way. Next use a 3/8 allen wrench to drain the fluid, look for metal pieces. Next take the six nuts off the six studs holding the t case to the trans. If your not on a serious incline dont worry about the t case falling off after you take the last nut off. Pull the case off and take inside. You should have this
Take off the rear tail shaft housing.
Remove snap ring, in my case i bought the t case saver.
anways it should look like this
remove the 9 bolts and two nuts holding the two cases together, there is no need to remove the oil pump housing, leaving it on makes things easier later. After the bolts are out pull the back half off.
Oil filter, tube, and pump stay in place
remove spring and cap, set aside
take snap ring off front drive gear
everything slides out now, just pull back, this is fun to do haha
i think it goes without saying but just be gentle with the parts and stay organized.
If you need to change the syncro ring or studs on the main shaft, take the snap ring off and everything slides off.
anyways the range slider and fork are left in the planitarry
they just come out with a wiggle
planitarry gear
next flip it over to take the input shaft and bearing and planitarry out. Remove the four bolts any pry the cover off.
remove the snap ring
gently hit/push down on the input and it falls right out
remove the snap ring holding the input shaft in and pull it out. There are two plastic thrust washers and one metal one in here.
after that you are pretty much done taking it apart, make sure you inspect all the parts super carefully now. First time i did it i missed the range slider and had to take it apart again. Ill take more pics of the rebuild but everything is just opposite.
1998 ECSB 12v 5 speed 18° 4k gsk 60lb springs tork-tech OFV fuel plate/silencer ring MIA 500hp/1000ftlb PF clutch boost fuel egt gauges 330k Blue 285/75/16 Goodyear Wrangler Silent Armor Pro
3.9 islander is offline   Reply With Quote
The Following 2 Users Say Thank You to 3.9 islander For This Useful Post:
moonshinerC10 (04-01-2013), yrslvp (01-16-2013)
Old 11-12-2011, 10:35 AM   #2 (permalink)
-continued-
Now for the fun stuff, seeing all the broken stuff
how it should look
worn range slider
Overall very straight forward all you need is snap ring pliers and a short and deep 15mm socket, everything is 15mm. It takes about 40min to get it out of the truck, about an hour to tear down and about an hour to put back together and about an hour to put back in. Places i used for parts were-
QUAD 4x4 Home Page have everything you need
Ring & Pinion, Transmission and Transfer Case Parts - Drivetrain.com transfer case saver
Transfercase parts transfer case chains best prices and friendly
Fluid is 3qts ATF DEX III/M (Advanced Auto)
Any questions let me know i am more than happy to help out, and of course
CUMMINS POWER!
The Following 6 Users Say Thank You to 3.9 islander For This Useful Post:
12valveterror (11-13-2011), 12VEG (07-09-2012), 98whitelightnin (09-19-2012), Mat_Burn (05-11-2013), novakane8703 (05-15-2013), uppersalmon (04-13-2012)
Old 11-12-2011, 01:26 PM   #3 (permalink)
#1_Cummins's Avatar
This is an AWESOME write up! every write up should be this good. great details and pictures (They really help!) i would definetely recommend this to anyone rebuilding their NP241. if it wasnt for write ups like this, i would be totally lost on half the things that i do!
'94 2500 Cummins! NV4500 5spd --SOLD
'05 F 2fidy... 6.0 all stock except for dual exhaust
#1_Cummins is offline   Reply With Quote
Old 11-12-2011, 09:05 PM   #4 (permalink)
thank you sir! I figured i could help out some people who will be in the same boat that i was!
Old 11-13-2011, 04:11 PM   #5 (permalink)
12valveterror's Avatar
iTrader Score: 9 reviews
Great writeup, having submitted several writeups myself, its always good to see new ones and I was actually curious on how this went. Thanks!
Engine: Mahle "Marine" Pistons, Balanced Rotating Assembly, ECD Cam, O-Ringed Block, Ported/O-Ringed Head, 3 Angle Valve Job, ATI SuperDamper
Fuel/Air: 475cc P-Pump, 5x.014's, Airdog 150, BW 66/68/14
12valveterror is offline   Reply With Quote
Old 11-13-2011, 05:06 PM   #6 (permalink)
Thank you sir, they are a huge help to a lot of people. This was the third time i took it apart so all the problems should be fixed now
Old 11-13-2011, 05:56 PM   #7 (permalink)
great job man! should be a sticky....good pictures are worth 1000 words
1997 eclb 2500 4x4, nv4500, haisley street/drag DD w/1.375 shaft, afc mods and no plate, 16.5*, conta!gous 5x14s, 024s, 4k gsk, hx35/ht60 twins, 5" tbe, airdog 165, tork tek 060, ARP studs and o-ringed head, guages, 2.5 level, 325/60 nitto's 18" ions
4x4flatbed is offline   Reply With Quote
Old 11-15-2011, 11:37 AM   #8 (permalink)
HEY ISLANDER. look inside your input shaft and you can see the wear on the inside. that is where the hub rides that you have a pic of.
flurryoftexas is offline   Reply With Quote
Old 11-15-2011, 11:51 AM   #9 (permalink)
yeup i anticipated that so i bought the input shaft, slider hub, and range fork. installed all of them and its working great!!
thanks flatbed!!
