Front Axle Seal Leak - Dodge Cummins Diesel Forum
94-98 Chassis Tech articles dealing with brakes, suspension, steering, wheels, etc.
post #1 of 1 (permalink) Old 05-14-2010, 11:38 AM Thread Starter
If your front seal(s) leak after front end work waiting is the best thing you can do.
If the u-joint isn't supported in the stock position when the rotor is removed the seal gets deformed, fluid gets by and trapped in the axle tube.
When the axle is back in the normal position the seal will reseal but is still takes a long time for the oil that got by it to leak out, sometimes at least 500 miles.
You can speed up the drainage by parking the truck tilted toward the leak.
Don't overfill the differential, 3/4" below the bottom of the fill plug is spec.
Anything more and it's guaranteed to leak.
If in a few weeks from it's still leaking go here> Front Axle Tech
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
The Following 3 Users Say Thank You to illflem For This Useful Post:
baer's cummins (09-25-2010), dwr91 (07-30-2010), JohnnyNitrous (05-24-2010)
