Go Back   Dodge Cummins Diesel Forum > Classified Ads > 94-98 2nd Gen All Products
94-98 2nd Gen All Products For Sale: All Items related to the second generation of Dodge Diesels. (1994 to 1998 Dodge Ram Diesels)
Old 11-03-2009, 01:08 AM   #1 (permalink)
1997 "G-Thang" Rolling Chassis & Motor
As stated "G-Thang" is up for grabs the motor is also for sale I have itemized list for the motor of all the parts and prices aswell. I will post that later. For now this is the rolling chassis!
97' Reg Cab Longbed
60 Front
ARB
5.13's
Posi-Loc
Spicer Joints
ARB compressor and lines also included
80 Rear
SCS Mini Spool
SCS axles
5.13's
Mag-Cover
1480 Yoke
NV-4500
Big Shaft
EEP Billet DD (SFI)
241 DHD
1480 Slip Yoke
NEW DS
Rims 16x12" MT Classic II's
comes with bald 33's and wagon spoke rims also
Gauges
Pillar Pod
Phantom II's
Pyro
Boost
Steering Column Pod
DP Gauge
Gas Cluster 6K
Radiator
DP all the exhaust 5" Stack in bed
Fuel Cell
5/8" Lines
AN fittings
A-1000 Pump
A-1000 Bypass reg
A-1000 Stainless Filter
2 Micron Filter water/fuel
$10,000
Motor will be sold also minus the pump, injectors, turbo.
Have build sheet and all the info I will post it later motor was brand new for 09' has roughly 20 hooks on it.
$10,000
I could also make you a turn key 2.6", 2.8", or 3.0" ready to run for
$30,000
If you know what stuff is worth u will know that this is highway robbery.
Brandon
97' CTD is offline   Reply With Quote
Old 11-04-2009, 01:44 AM   #2 (permalink)
Specs on the engine!
CR Pistons-coated and fly cut
Cam Bushings
Fire Rings Copper HG
Total Seal Rings
Main Studs
Billet Side Cover
Balanced
Lightened USA Rods
New Cummins Oil Pump
Coated Bearings
Polished Crank
Hd Rod Bolts
New Water Pump
Billet Freeze Plugs
Valve Guide Liners
Valve Job-Port and Polish
Intake Milled-6" Individual Tube Intake
Titanium Keepers and Retainers
Head Studs
Rocker Studs
High Performance Springs
Fluid Dampner
Thick UG Custom Grind
T4 ATS Manifold
Coolant Recirc Kit
Billet Push Rods
Girdle
Probably Forgetting Stuff This is What i can think of for now.
Brandon
Old 11-07-2009, 11:17 PM   #3 (permalink)
Space Shuttle Door Gunner
Caleb S's Avatar
bump for your Brandon. I have seen your truck pull a few times and it is very well put together. Someone is gonna get an awesome set up here
98 2500 4x4 5SP
Caleb S is offline   Reply With Quote
Old 11-07-2009, 11:22 PM   #4 (permalink)
Thanks buddy!
Brandon
Old 11-07-2009, 11:58 PM   #5 (permalink)
SupaFast!'s Avatar
id like to have the gauges lemme know
97 No plate 2wd EXT Cab 4' exhaust 5spd 3k springs 150shot 191DVs #2 97 1ton no plate/370s
SupaFast! is offline   Reply With Quote
Old 11-09-2009, 02:58 PM   #6 (permalink)
PROUD COAL ROLLER
12vredneck's Avatar
brandon has done alot of work on my truck this truck of his is bad hes a good buddy of mine and believe me you wont be dissappointed
1994 2500 4x4 goerend auto,new paintjob,20" rims,5" exhaust,no fuel plate,pro comp suspension,4:10 gears,triple gauge pod, ,l.e.d lights,tow mirrors,, LOTS OF PUMP WORK, 191 SCHIDE LASER CUT DELIVERY VALVES, John Deere intake, 2.5" leveling kit, 435 Injectors, 4k gov springs, airdog 150gph fuel system, HTT PROSTREET 66/71/16 TURBO, ATS manifold, 12MM STUDS, 6OLB SPRINGS, DEEP TRANNY PAN, TRACTION BARS
OHIO COAL ROLLERS
12vredneck is offline   Reply With Quote
Old 11-10-2009, 07:45 PM   #7 (permalink)
Part time puller's Avatar
Bump.....
Great running truck... Turn key and DONE RIGHT!!!!!
Part time puller is offline   Reply With Quote
Old 11-12-2009, 11:11 PM   #8 (permalink)
Dallasfire911's Avatar
parting out?
97' 3/4 ton custom exhaust, gauges, 36psi 35x, MANUAL fuel shut off, BHAF, Auto soon to be Manual, did i mention 25mpg? and more to come!
Dallasfire911 is offline   Reply With Quote
Old 11-13-2009, 03:17 AM   #9 (permalink)
Nice truck seen it run a ton of times BTT.
96 ext cab long bed Silencer Ring removed, No fuel plate, 4in turbo back, K&N Intake,...more to come
twarek04 is offline   Reply With Quote
Old 11-13-2009, 12:27 PM   #10 (permalink)
Motor is SOLD.
Chassis is pending.
Brandon
Old 11-13-2009, 03:39 PM   #11 (permalink)
ODIEUB's Avatar
glad you've been able to move it, and thanks for the purchace.
01 HO w/215 12v, ddp, helix II, sbc dd, almost complete
94 2wd daily driver 565k, mostly stock 25mpg 913 PUMPED
special thanks to all those who have helped.
ODIEUB is offline   Reply With Quote
Old 11-13-2009, 07:03 PM   #12 (permalink)
Good deal.. Glad you got a good truck!!!!!!
Sent ya a PM ODIE
