Go Back   Dodge Cummins Diesel Forum > Classified Ads > 94-98 2nd Gen All Products
94-98 2nd Gen All Products For Sale: All Items related to the second generation of Dodge Diesels. (1994 to 1998 Dodge Ram Diesels)
Old 09-21-2009, 12:38 AM   #1 (permalink)
BigDodge59's Avatar
47RH Race Valve body
SunCoast Race Valve Body for 47RH. never used. it was built for a spare. we have now change things all around and no longer need it. $375.00 with a core.
96 12v 3500, 96 12v 2500 4x4, 95 318 1500, 99 360 1500 4x4
95 24v 1500. 6.07@120mph,9.34@148.53mph
Southern Diesel Performance (205)533-0453
BigDodge59 is offline   Reply With Quote
Old 09-21-2009, 11:04 AM   #2 (permalink)
Young Gun
What is it mean by a race valve body? Ik its built but is there anything different with a race then a normal built VB
1995 Dodge ram 2500 4x4 12valve, auto, leveling kit, Boost, pyro, and FP gauges, starwheel turned, #10 plate, KDP tabbed, 60# valve springs, 4k GSK, timing 16.5*, Luke's Link track bar, 215 injectors.
hartman is offline   Reply With Quote
Old 09-21-2009, 12:41 PM   #3 (permalink)
PROUD COAL ROLLER
12vredneck's Avatar
can u still pull with this valve body
1994 2500 4x4 goerend auto,new paintjob,20" rims,5" exhaust,no fuel plate,pro comp suspension,4:10 gears,triple gauge pod, ,l.e.d lights,tow mirrors,, LOTS OF PUMP WORK, 191 SCHIDE LASER CUT DELIVERY VALVES, John Deere intake, 2.5" leveling kit, 435 Injectors, 4k gov springs, airdog 150gph fuel system, HTT PROSTREET 66/71/16 TURBO, ATS manifold, 12MM STUDS, 6OLB SPRINGS, DEEP TRANNY PAN, TRACTION BARS
OHIO COAL ROLLERS
12vredneck is offline   Reply With Quote
Old 09-21-2009, 08:54 PM   #4 (permalink)
MS Chapter President
2141pete's Avatar
Is it a manual VB? from what I understad if I go with a manual VB I can do away with the TPS and not have to worry about it.
2002 dodge 2500 4x4 24v, 175 pump, 4k GSK, 191 DV's, Mack plug, .093" lines and tubes, HD Cam, twins, 8x.011's, and a few other things
2141pete is offline   Reply With Quote
Old 10-17-2009, 11:40 AM   #5 (permalink)
MileHighCTD's Avatar
Still selling the valve body?
1995 12V SC 4x4, S300, #0 plate, 4" Shorty
Daily Driver - 2002 QC 4x4 Sport, TST PM3 Comp, Smarty, S-300/S-400 Twins, Mach 4's, 150gph F.A.S.S., 5" Shorty, 38" TSL Radials. Love diesels, thank you Rudolph!!
MileHighCTD is offline   Reply With Quote
Old 10-21-2009, 05:38 AM   #6 (permalink)
ridemoto4life's Avatar
interested in the valve body. more info please
91.0' W350 SRW LE. 727 3.54s, Dana 80 LSD, 265/75R16E, 366 spring, THIN pin, pump maxed, what starwheel? timing bumped, BHAF, 3.5" straight pipe, rear bagged, Isspro gauges, Hella H4s, Borg shaft.... COMING SOON! big sticks, HX40, 47RH/NV? & DRW swap
ridemoto4life is offline   Reply With Quote
Old 11-07-2009, 08:50 PM   #7 (permalink)
ShortBedCrew's Avatar
Anybody picked this up yet, Im looking for one....
1981 chevy 1 ton crewcab,shortbed, 95' CTD,HX35/ST50 twins,#100 plate, 15* timing, boost elbow,385 hp injectors, 4" exhaust, BHAF,3K gsk,SB clutch,8" lift,205tcase,4.11s,14r/60f both w/detroits,38"toyo MTs,18x10 chrome.SHES A BEAST!
ShortBedCrew is offline   Reply With Quote
Old 11-07-2009, 08:51 PM   #8 (permalink)
BigDodge, you got PM
Old 11-07-2009, 09:59 PM   #9 (permalink)
BigDodge59's Avatar
still got it. sorry i have not being on this site in a little bit. it will shift at wot @3800. it is still auto and does not use tv cable.
Old 11-09-2009, 12:29 AM   #10 (permalink)
Yikes, 3800? Is there any way to change that? My truck wont even go that high! When just driving around normal does it act like a regular valveboby? Sorry for the dumb questions, still learning these trannys. I guess I could get the 4GSK conversion and valve springs.......
Old 11-10-2009, 12:19 AM   #11 (permalink)
BigDodge59's Avatar
yes it will shift sooner at less pedal. i am not sure how they do it but if i drove around on the street it would shift hard but at 2000rpm.
you can lower the shift pionts also.
