blew the freeze plug - Dodge Cummins Diesel Forum
Old 11-17-2008, 02:27 AM   #1 (permalink)
Blue01Cummins's Avatar
i was with a buddy tonight we were racing and it started leaking antifreeze. We started looking around and a freeze plug on the back of the block blew out how did that happen? and how do i put a new plug in the back of the block? It is and 2003 thanks rich
2001 Dodge Ram 2500, 6 speed, Gauges pyro and boost, AirDog 150, 150 Horse fireball injectors, 4in exhaust..
Blue01Cummins is offline   Reply With Quote
Old 11-17-2008, 09:11 PM   #2 (permalink)
does anyone know how i can put a new one in?
Old 11-17-2008, 09:40 PM   #3 (permalink)
Rollin Coal's Avatar
put some red loctite on it and tap it in w/ a rubber mallet. but until you fix the issue your going to keep having probs.
im going to guess headgasket is leaking combustion pressure into coolant passage.
R.I.P. Jonathan Link
Rollin Coal is offline   Reply With Quote
Old 11-17-2008, 09:57 PM   #4 (permalink)
Innovative Diesel
DODGE74's Avatar
iTrader Score: 15 reviews
Thats what it sounds like to me
Cummins EFILive and Smarty UDC custom tuning specialists
Check out our build thread! http://www.cumminsforum.com/forum/in...hop-truck.html
https://www.facebook.com/innovativediesel?fref=ts
www.innovativediesel.com
gordon@innovativediesel.com
866-642-7844
DODGE74 is offline   Reply With Quote
Old 11-17-2008, 10:16 PM   #5 (permalink)
was the engine cold
programmers don't detune when the engine is cold and when the thermostat is closed the pressure the water pump creates in the block will blow the freez plug out of the back of the head. it is a common problem. and some truck can have it happen when the thermostat is open, some body sells a kit it is a plate that goes over the opening and holds it in.
TDI.
gator6 is offline   Reply With Quote
Old 11-17-2008, 10:16 PM   #6 (permalink)
RDyson's Avatar
I blew mine about 5 months ago. I had just got the TNT software that raised the rpm's a little bit. I was trying to get my tune--fine tuned by doing several WOT runs north of town.
After much research, the concensus is the warmer than normal engine--from the 8-10 WOT runs and the higher rpm's causing more coolant pressure in the block pushes the freeze plug out.
I found a replacement plate from Enterprize Engine Performance to plug the hole. It is a billet aluminum plate with 3 holes that match holes on the back of the block to attach it.It has a machined plug with an o-ring to plug the hole. I had to remove the right front tire and the inner fender liner to be able to get to the bolts. But I was able to install it without dropping the tranny.
It cost about $45 before shipping. It wasn't easy to get installed, but at least I didn't have to pull the tranny.
Randy
03 SO/Auto, QC/4X4, TST/Smarty/Puck, Boost/Fuel/Pyro/Rail Pressure, SPS-62, Goerend, Airdog, Arson Kit, GDP Power-Flo, , Fuel Tank Vent Mod, Donaldson 51", Wicked 50's, ARP, 613/1171, 13.16@108.2
RDyson is offline   Reply With Quote
Old 11-17-2008, 10:19 PM   #7 (permalink)
409Cummins's Avatar
when you install it dont use a punch! use a socket just a hair smaller than the plug
Nathan
2006 Ram 3500 Inferno Red Big Horn 5.9/Auto
1998 Chevrolet K3500 454/Auto
2010 Challenger B5 Blue SRT8 6.1/6spd
1967 Dodge Coronet PPG7000 Black 383/4spd
409Cummins is offline   Reply With Quote
Old 11-17-2008, 10:30 PM   #8 (permalink)
ive never head of the water pump causing pressure issues on a 2nd gen, only 3rd gen
Old 11-18-2008, 02:20 AM   #9 (permalink)
RDyson's Avatar
In the first post, he said it was a 2003.
Randy
Old 11-18-2008, 03:11 PM   #10 (permalink)
oh missed that i was going by his sig
Old 11-19-2008, 02:00 PM   #11 (permalink)
Nohel's Avatar
i found the kit to eliminate the problame BOE Kit
06 -2500 4X4, SMARTY TNT, ATS manifolds, fass 150, Afe, htt 64/71/14, turbo max intercooler, some cp3's, 90hp sticks, TST,,6" stack, Lorenz 2.5 suspension, Toyo MT, autometer,HTS full billet trans627Hp 1200+LBft
Nohel is offline   Reply With Quote
Old 01-16-2009, 03:20 AM   #12 (permalink)
Gone Fishing!!
pro99's Avatar
You might have to be a licensed plummer with that kit
pro99 is offline   Reply With Quote
