Old 10-04-2008, 04:09 PM   #1 (permalink)
2002 Not starting
I just got a 2002 2500 with an automatic. Starts sometimes and runs great. Other times it takes forever to start and runs bad for a few minutes. The lift pump has been replaced with a holley blue frame mounted. You can hear it running when the key is on. Fuel filter changed. Any ideas? Is there a on off solenoid on this model? Thanks
Black Oak Smoker is offline   Reply With Quote
Old 10-05-2008, 07:25 AM   #2 (permalink)
TECH SPECIALIST
JWH_03_Dodge's Avatar
any codes? Here's a bump to catch the eye of the 2nd gen guys that knows what the deal on the VP44 is.
'03 2500, 4x4, 5sp, QCLB, 90hp injectors, Glacier Fuel System, Quad Race Box, 5" exhaust, still looking for my silencer ring and muffler
JWH_03_Dodge is online now   Reply With Quote
Old 10-05-2008, 07:55 AM   #3 (permalink)
Super Moderator
Caleb S's Avatar
Yeah do the key trick and tell us what codes show up. That will help in diagnosing the truck.
Also sounds like you need to make sure you are getting fuel to the VP44. So you can crack the #1 injector line or the VP banjo bolt and then bump the starter to send fuel towards it and make sure you get as steady stream. That will help to make sure you are getting fuel where needed and narrow down possible problems.
If you are getting good fuel from the lift pump to VP then it could possibly be an injector or maybe VP issue. Just my thoughts, but once again check for codes and let us know what you get
98.5 2500 QC/SB 4x4 5SP, FASS 95 HPFP, DiPricol OPTIX FP/Boost/EGT, AFE STAGE I PRO DRY, EDGE COMP, 150HP FBD Sticks, .093 Tubes, 5" TB to Single 7" MITRE
Caleb S is offline   Reply With Quote
Old 10-05-2008, 09:34 AM   #4 (permalink)
the code that appears is P PCU.
Old 10-05-2008, 09:40 AM   #5 (permalink)
cameronc's Avatar
should say a code after that if ther is one
2001,48re w/ Suncoast Valve Body, 4'' exhaust, airaid intake amsoil filter, Quad Xzillaraider & Edge EZ, Bd Stealth plate, Vulcan Big Line Kit& Blue, gauges:SOLD
Looking for a 2wd 12v now
cameronc is offline   Reply With Quote
Old 10-05-2008, 09:41 AM   #6 (permalink)
followed by no codes. So back to square one. If the injector pump was bad would it continue to run most of the time? This is a starting issue. Once started it never stops and runs fine. Although on starts that take awhile it will act up for a couple of minutes.
Old 10-05-2008, 10:31 AM   #7 (permalink)
Sounds alot like my issue, but once it starts and acts up it never clears up unless restarted. I'd love to know what fixes it for you. BTW, mine has a new injection pump and it still does this.
1999 2500 24V 5.9 138k miles
New VP44 and inline lift pump.
Justinlhc is offline   Reply With Quote
Old 10-05-2008, 01:41 PM   #8 (permalink)
5.9 guy's Avatar
I would put a fuel pressure guage in to see what it is runnin 15psi at idle no more than 20psi and 5psi min at wot preferable 10psi min at wot
02 2500 extended cab edge comp/drag box, K&N intake, 4 in MBRP exhaust, built trans, billet converter,HTS valvebody, autometer guages (trans temp, boost, egt, fuel press) bd frame mount lift pump, silencer ring moved out , lock-up switch
5.9 guy is offline   Reply With Quote
Old 10-05-2008, 06:51 PM   #9 (permalink)
It shouldn't need 15psi to idle, should it? Mine was idling at 8psi.....well sometimes.
Old 10-12-2008, 11:41 PM   #10 (permalink)
update on problem. Seems to be starting better now, however usually on a cold start after warming up I will take off and the turbo doesn't kick in. After about a mile it will start running fine and continue to run fine. Any thoughts on what that it could be now? It was doing similar before, now the only difference is that it seems to be starting better.
Old 10-13-2008, 03:55 AM   #11 (permalink)
tdcummins's Avatar
Gey your money back!
2002 CTD LWB EXTC, T409 Motoblue 4" exhaust, Auto meter gauges(Boost, Tranny, lift pump, & EGT), Transmission good for 750hp, bulit by AAMCO. Smarty Programmer, FASS 150/95......JDiepstra is my hero!
tdcummins is online now   Reply With Quote
Old 10-13-2008, 04:21 AM   #12 (permalink)
Upstate Diesel Performance
Diesel Dummy's Avatar
Check to make sure all you connections on the fuel ines are tight and not sucking air, I put a good used vp on and it did the same thing, so i went to a new one, same thing, after 3 months in the garage and a lot of frustration i found a broken clamp that was sucking just enough air so it would not start. Make sure wheen you do the key trick you let it finish, there will be ecu done and pcu done and then back to the odometer.
DD
If you need it we sell it! if you think you need it, we sell it! Even if you don't think you need it, but want it, we sell it! Thats it.
Upstate Bombers Site
Diesel Dummy is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
