Old 10-03-2008, 10:00 AM   #1 (permalink)
Ryan_m83's Avatar
Air in the lines?
Quick question for ya, I'm putting a issopro mechanical guage in between the VP44 and fuel filter, am I going to have to bleed the system or will I just be able to pump the starter a few times to prime it up again? and if not which bolt do I crank to drain the air??
Thanks
2001 24V CTD 4x4 QC- Edge Drag Comp, hx40 turbo, DTT controller/lockup, FASS, AFE intake, turbo silencer MIA, Mag-Hytec, 4" stainless exhaust, autometer gauges, fuel pressure gauge, rancho shocks w onboard air, Dueler A/Ts, 390rwhp & 817tq & 21-24MPG.
Ryan_m83 is offline   Reply With Quote
Old 10-03-2008, 10:03 AM   #2 (permalink)
GA CUMMINS CREW PREZ
SOUTHERN SMOKE's Avatar
what i would do to be safe, is bump the starter, to get the lift pump to prime, then, that should push your air out, and you should be good to go....
CLICK---> GEORGIA CUMMINS CREW 2003 CTD SMOKIN' BLACK BEAUTY... QCSB 4x4 6-SPD...AUTOMETER BOOST, FUEL, OIL...2ND GEN 24V INTAKE HORN...EDGE J/A... B&W TURN-OVER... QUADZILLA R/P...RECON L.E.D. RUNNING LIGHTS... RECON LINE OF FIRE...33X12.50 COOPERS...SRT-10 HOOD...XM RADIO...THEY CALL ME SMOKEY...
SOUTHERN SMOKE is offline   Reply With Quote
Old 10-03-2008, 10:08 AM   #3 (permalink)
Ryan_m83's Avatar
awesome, Im thinking I might replace that entire rubber line while im at it. Hopefully that works!
Old 10-03-2008, 10:09 AM   #4 (permalink)
should i dont see no problem why it shouldnt, just remember to make sure you have all the air out, no fuel to the vp44= no lubrication, and she will kill over if you aint careful, always double check yourself, before you fire her off...
Old 10-03-2008, 10:12 AM   #5 (permalink)
Ryan_m83's Avatar
To do this would I just crack the end of the fuel line thats on the VP44(the one that im replacing?)
Old 10-03-2008, 10:19 AM   #6 (permalink)
if you really want the air out of everything, i would crack the line, going into the feed tubes on the side of the block for the injectors, but yea, either was you can do it, just make sure all air is out of the truck... and she will fire right up...
Old 10-03-2008, 10:47 AM   #7 (permalink)
Ryan_m83's Avatar
Under the VP44 I see 6 lines that go to the injectors, not sure where on the side of the block your talking about :S
Old 10-03-2008, 12:16 PM   #8 (permalink)
yea there is one line for each injector, also there is a test port on the pump, you can open it and prime the lp, any way you want to do it just to get the air out...
Old 10-03-2008, 08:39 PM   #9 (permalink)
Ryan_m83's Avatar
all i did was bump the starter a few times and it fired right up! Everything works great. Thanks!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
