Old 10-02-2008, 09:08 AM   #1 (permalink)
Vibration at 60-70 mph
I have a 07 3500 4 X 4 standard cab dually lifted 6" 37" tires. Recently developed a vibration at 60-70 mph. checked u joints on the rear and found one bad. Pulled the drive shaft had both u joints replaced. After reinstalling the shaft and driving I still have a slight vibration that I feel in the floor board, and in the seat. I dont feel it in the steering or the the gear shift. Could it be the tires out of balance? or driveshaft out of balance? Please help.
07RAM3500 is offline   Reply With Quote
Old 10-02-2008, 10:51 AM   #2 (permalink)
is the driveline angle bad?
2001.5, 6 speed, leveled, 285s, 4in turbo back to dual 6in mitre, adr w/pulse, s&b intake, boost elbow, raptor 150, 1/2in big line kit, draw straw, custom fuel filter off of detroit series 60, stage 4 jammers, isspro mech. fuel pres. gauge
nbaca is online now   Reply With Quote
Old 10-02-2008, 10:54 AM   #3 (permalink)
With a 6 inch lift front U joints could be bad.
Quadman is online now   Reply With Quote
Old 10-03-2008, 11:26 AM   #4 (permalink)
checked the front u joints and they are tight, no signs of wear on them. As for the angle of the rear driveshaft at the pinion, maybe 3 degrees down.
Old 10-04-2008, 06:44 PM   #5 (permalink)
totalloser's Avatar
Probably an irregularity in the carcass of a tire or an out of balance wheel. Rotate your tires. Irregularities are somewhat common, and unavoidable. The reason you are hitting it at 60 t0 70 is the tire size. This problem usually occurs at lower speeds due to tire rotation speed. IE Bigger tire turns slower, so problem occurs at higher speed.
01 24v 100hp tips, 4"ss BDbrake &steering brace PSCpump 1.5"dom steering tapped box 1.5"ram manual CAD switch dual carters 3.55's LSD, big shaft nv5600/241HD 6 35's inners pulled in (no spacer) Ugly black and thrashed!
totalloser is offline   Reply With Quote
Old 10-05-2008, 07:16 PM   #6 (permalink)
Tech Specialist
the last 6" lift I did had the same problem - i called tech support and found that i had to change the caster of the front differential - fixed the problem - just a thought
Ramtech is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
