Check Engine/ Dead Pedal
98.5 24v 270k miles Check engine light came on tonight, im pretty sure its a dead pedal. It seems like there is only 1/4 throttle no matter what i do. I press down wot in any gear and nothing happens. Im supposed to pull a horse trailer tomorrow. is it even possible? And i have tried and tried and i cant do the key trick to check codes...?
#2 (permalink) |
Cummins Freak!!
if you can get it to a schucks or auto zone or some where that has a code reader and see if they will pull the codes i think it might be the map sensor not 100% on that someone will know a little more im sure
2001 Dodge Ram 2500 CUMMIN'S 5spd 4x4 south bend con o clutch, stg 1 injectors, leveling kit, air bags in the rear,315/75r16 TOYO M/T, straight piped, silencer MIA, Edge Juice with Attitude w/ pillar mount, Airdog 150(18psi at an idle,16psi wot), second VP44, soon to come BHAF!
#3 (permalink) |
Cummins Freak!!
o yea the key trick doesn't work a 98.5
#4 (permalink) |
it is youre APP sensor.. (Accelerator Pedal Position Sensor) mine has done that for about 6 months now cause i dont want to spend the crazy amount of money that they want for one.. u should be fine it will just have no throttle for a few seconds and kick back on its really annoying..
1998.5 24v quad cab, longbox,4x4,auto 210k..silencer ring MIA,straight pipe,BHAF,superchip, 5'' mitre cut stacks,soon to do a 5 spd conversion |
#5 (permalink) | |
The problem is it doesnt kick back on...or at least i havent been able to get it too. I tried the APPS reset but nothing changed but im not sure i waited long enough johnnyboy- thank you that makes me feel better about the 98.5 i was getting frustrated |
#7 (permalink) |
i worked at dishman dodge in spokane for awile in the service department and this was pretty common on these years..some trucks would not kick back on and were towed in but 9 out of ten would kick back on... HERES MY EXPIERIENCE- I was driving about 40mph and all of a sudden no throttle or response at all (DEAD PEDAL) and it would not kick back on so i rolled into the closest parking lot and watched in horror as my check engine light was on and my truck was just idling there helpless. i shut it down and fired it right back up and it drove away with the chk engine light still on..took it to work the next day and ran the computer through it to have it come down to the APP sensor which at my cost was 400 bucks... P.S I hope that helps
#11 (permalink) |
Start with the codes first-you need to know where the problem lies. It may not be APPS related at all. Do you know what the fuel pressure is on the truck?
98.5 3500 2WD dually 4:10's lAuto Meter fuel, boost, pyro, and trans temp lOne piece headlights+ LED's l5 inch mitre stacks lHX 40 l150 horse Coaltrain sticks l.093 tubes l Smarty lEdge Comp HOT lStage 2 snow kit lBHAF lBD pusher pump lAmsoil, engine+diff |
#12 (permalink) | |
I think i will take it to autozone today to get the codes checked. No i do not know the fuel pressure, i have yet to get a set of gauges. how else can i test it? can i buy a fuel pressure gauge that is meant for diagnostics that will hook up to the cummins? could it be my fuel filter? i dont know the last time it was changed. |
