Old 10-03-2008, 11:41 AM   #13 (permalink)
99,24v auto .autozone will not check codes anymore in northern ca,but my cruise stopped working.the cruise light goes out when you set speed and will not come on again till you restart.vac is around 20in. no codes. replaced the ess,checked servo looks good and the lines and fitting also.break swithch seems ok?????????
fearnaut is offline   Reply With Quote
Old 10-03-2008, 04:54 PM   #14 (permalink)
Steveo24's Avatar
Well, my next step would be to change the fuel filter, check the air filter, coolant level, etc.. All the basics, if you cannot pull codes. Fuel filter ASAP, supposed to do them like every 5000 miles or so, so for the 20 or 30 bucks that it costs, I would definately do that first.
98.5 3500 2WD dually 4:10's lAuto Meter fuel, boost, pyro, and trans temp lOne piece headlights+ LED's l5 inch mitre stacks lHX 40 l150 horse Coaltrain sticks l.093 tubes l Smarty lEdge Comp HOT lStage 2 snow kit lBHAF lBD pusher pump lAmsoil, engine+diff
Steveo24 is offline   Reply With Quote
Old 10-03-2008, 05:51 PM   #15 (permalink)
I bought a fuel filter so ill be doing that today.
I sucked it up and bought a scanner. autozone apparently doesnt do it anymore.
So my codes:
P1693
P0238- this one concerns me, i think it is a boost sensor reading too high? this might explain the sluggishness of the engine if something is wrong with the turbo?
Is this something i can fix?
weasel1088 is offline   Reply With Quote
Old 10-03-2008, 09:21 PM   #16 (permalink)
Steveo24's Avatar
1693 always comes up to show there is another code stored in the JTEC module. However the 238 code is Map sensor voltage to high. That would explain the way it is running. Do a search on this forum on how to clean the MAP sensor, could be an easy fix, or test and if bad-replace-good luck
Old 10-04-2008, 09:17 AM   #17 (permalink)
what if i unplug the map, reset the codes what will happen? i know i will get another code for the map but will it put me in the same limp mode im in now?
Old 10-04-2008, 09:52 AM   #18 (permalink)
Steveo24's Avatar
Probably run the same, but I have seen some of the connections in the plug get fouled up, might be worth tryin.
Old 11-03-2008, 08:26 AM   #19 (permalink)
My 01 did the same thing on a trip once, but mine would eventually kick back in. My idle speed also went up to 1,000 rpms and the engine cooled 10 degrees. I ran the cruise this weekend and my idle speed went back up and I only got 12.8 mpg...been averaging 16??? I have 3.55 gears and cannot undertstand the mileage unless it is due to my Edge Comp being set at level 3 stage five...definitely won't be using that setting on the interstate any more.
gauge is offline   Reply With Quote
Old 11-03-2008, 01:23 PM   #20 (permalink)
Turned out it was the map sensor. was about 100 bucks from the stealership but as soon as i replaced it, i was back at 100%
98.5 QCLB 4x4, 5spd, BHAF with silencer removed, 285's
Old 11-07-2008, 12:04 PM   #21 (permalink)
pedel pump
Mine throws a code for loss of throttle idle ref position, P0121.
I got a $40 reader from harbor freight, does the job.
To get pedel back I have to let my foot off all the way for a sec and then slowly push to the floor, let off again and I got pedal.
I guess it's the Fedex computer problem.
BoBo69 is offline   Reply With Quote
Old 11-07-2008, 12:13 PM   #22 (permalink)
Steveo24's Avatar
BoBo, alot of times when the APPS sensor is out of adjustment it will throw the PO 121. Do a search on ApPS adjustment, this will likely fix your problem.
Old 11-07-2008, 12:43 PM   #23 (permalink)
Thnx
Thanks Steveo, I'll look for the adjustment info.
Old 11-08-2008, 12:43 PM   #24 (permalink)
I had this problem happen last week. Ran codes and it was the apps sensor. Well they wanted over $500 for the part. I took out the sensor, cleaned the plug, put die-electric greese on the connectors and put the old apps sensor back in. Cleared the codes and the truck runs great again. Saved myself $500
Jammin is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
