2004.5 code P0148 - Dodge Cummins Diesel Forum
post #1 of 31 (permalink) Old 09-30-2008, 12:54 PM Thread Starter
2004.5 code P0148
I drove my 2004.5 for the first time in about a month today (somehow the wife seems to have inherited my truck) and it was low on power. I checked the codes and it throws a P0148, fuel delivery error. It also seems like when I mash the throttle at 60mph that I can hear a boost leak. Can a boost leak lead to a P0148 code
2004.5 RAM2500 CTD QUAD CAB SHORT BOX 4X4, NO MODS YET
1996 RAM2500 CTD REGULAR CAB LONG BOX 4X4, STRAIGHT PIPE
erikz is offline
post #2 of 31 (permalink) Old 09-30-2008, 01:15 PM
BILLS06's Avatar
High Pressure Common Rail. If it's low on power, you popped the relief valve. There's one of two ways to fix it: 1.Buy a new relief=$400 or cap it. But if you cap it you can wreck an injector if your not careful or you can cap it and see if power comes back.
06 QCSB SLT
Headlight Eyelids Fluidampr EZ Down ATS Converter Fog Lamps Aero Turbine Muffler Reflex Bed Liner
[SIGPIC][/SIGPIC]
BILLS06 is offline
post #3 of 31 (permalink) Old 09-30-2008, 01:37 PM Thread Starter
Is the pressure relief valve the same on a 2003 common rail CTD because I have access to one of those on a parts truck. Also, just to clarify, would a boost leak have any influence on the trouble code? Is it possible that what sounds like an air leak could actually be the relief valve acting up? Lastly, if I keep driving the truck like this can it cause any damage?
erikz is offline
post #4 of 31 (permalink) Old 09-30-2008, 01:41 PM
BILLS06's Avatar
The valves are the same. On the small boost leak, does it smoke black pretty good when you get on it?
06 QCSB SLT
[SIGPIC][/SIGPIC]
BILLS06 is offline
post #5 of 31 (permalink) Old 10-02-2008, 10:19 AM
Is there any way a dealer can check if the relief valve needs to be replaced. This code and loss of power has been a huge problem for me, and the dealer I have taken it to can never seem to find any problems with their scanner. The code is there, but they can't get it to duplicate the problem while test driving it themselves,(next to no power, etc as mentioned in many other threads). Don't want to hyjack the thread, but just wanted to bring a question up. Doubt the dealer will take my advise and swap the valve, based on some internet research.
2004.5 2500 CTD: 5" Skyjacker Lift, 35" Nitto Mud Grapplers, 18" Motto Metal 951, Smarty, AEM Brute Force, 150 Litre Slip Tank, Burning Nothing But Free Fuel!
Burgo is offline
post #6 of 31 (permalink) Old 10-02-2008, 12:09 PM Thread Starter
Don't worry about hyjacking my thread. I want to get all the info I can. Burgo, does your truck do this all the time or is it intermittent? Mine doesn't always do it. It gets pretty annoying when you want to pass someone and you don't know if your truck is gonna be a rocket or a slug. With all this computer/electoronic stuff on our trucks you would think it should be easier to diagnose these pesky problems. Oh, I checked all my turbo to intercooler connections and everything appears OK. I also don't seem to get any extra black smoke.
erikz is offline
post #7 of 31 (permalink) Old 10-02-2008, 12:29 PM Thread Starter
I also wanted to ask where the FCA was and how hard is it to remove or test? Also, if I change the rail pressure relief valve what's the approximate torque on the unit? Thanks.
erikz is offline
post #8 of 31 (permalink) Old 10-02-2008, 01:16 PM
BILLS06's Avatar
FCA is on the back of the injection pump, 3 screws and a connector is all it takes to remove it. The dealer will have to drive it around with the star scan to see what rail pressure is @ wot and at idle. Torque on the valve is 52 ft/lbs and the banjo bolt is 18 ft/lbs
06 QCSB SLT
[SIGPIC][/SIGPIC]
BILLS06 is offline
post #9 of 31 (permalink) Old 10-02-2008, 07:43 PM
Pursuing the Great Commission
JWH_03_Dodge's Avatar
here's P0148 from Chrysler's database, just for some background reading of what all can set the code:
P0148-HIGH PRESSURE COMMON RAIL (HPCR) CHECKSUM
For a complete wiring diagram Refer to the Wiring Information.
When Monitored:
While the engine is running.
Set Condition:
A deviation between the fuel pressure set point and the actual fuel pressure.
Possible Causes
OTHERS DTC'S PRESENT
FUEL LEAKS
FUEL CONTROL ACTUATOR
FUEL PRESSURE SENSOR
CASCADE OVERFLOW VALVE
CHECK VALVE DAMAGED OR BLOCKED
FUEL RETURN LINES OBSTRUCTION, DAMAGE, OR DEBRIS
LIFT PUMP FLOW
AIR IN FUEL SYSTEM
LEAKING FUEL INJECTORS OR HIGH PRESSURE CONNECTORS
PRESSURE LIMITING VALVE
HIGH PRESSURE FUEL PUMP
INTERMITTENT CONDITION
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Engine Control (ECM) - Standard Procedure)
1. OTHERS DTCS PRESENT
1. With the scan tool, read DTCs.
Are any other DTC's present?
Yes
Repair other DTC's first.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 28 - DTC-Based Diagnostics/MODULE, Engine Control (ECM) - Standard Procedure)
No
Go To 2
2. FUEL LEAKS
1. Ensure that the fuel level is above 15% using the scan tool.
2. Visually inspect the low and high pressure side of the fuel system for fuel leaks or damaged components.
Do you have any fuel leaks or damaged components?
Yes
Repair the fuel leak.
No
Go To 3
3. FUEL CONTROL ACTUATOR
1. Check for a mechanically stuck Fuel Control Actuator (FCA). Using the scan tool, actuate the fuel control actuator.
NOTE: The fuel control actuator will only click when cycled off.
Do you hear a click from the actuator when you cycle the actuator off with the scan tool?
Yes
Go To 4
No
Replace the fuel Injector pump.
4. FUEL PRESSURE SENSOR
1. Using the scan tool, monitor the fuel pressure reading from the fuel rail pressure sensor at idle and at 2000 RPM
Is the fuel rail pressure reading higher at 2000 RPM than at idle?
Yes
Go To 5
No
Replace the fuel pressure sensor.
5. HIGH FUEL PRESSURE
1. Using the scan tool compare the fuel rail pressure set point with the actual fuel rail pressure.
Is the actual fuel rail pressure higher than the fuel rail pressure set point?
Yes
Go To 6
No
Go To 9
6. CASCADE OVERFLOW VALVE
1. Perform the no trouble code test "*fuel pump return flow test" .(Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing)
Did the fuel injection pump pass the test?
Yes
Go To 7
No
Replace the Fuel pump.
7. CHECK VALVE DAMAGED OR BLOCKED
1. Check the fuel drain line check valve in the rear of the cylinder head for signs of damage, blockage, or debris.
Is the check valve damaged or blocked?
Yes
Repair the cause of the damaged or blocked check valve or replace the valve.
No
Go To 8
8. FUEL RETURN LINE OBSTRUCTION, DAMAGED OR DEBRIS
1. Check the fuel return lines for signs of obstruction, damage, or debris.
Are the fuel drain lines damaged or blocked?
Yes
Repair cause of high fuel drain line restriction.
No
Go To 9
9. LIFT PUMP FLOW
1. Perform the no trouble code "*LIFT PUMP FLOW TEST". (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing)
Did the Lift pump pass the test?
Yes
Go To 10
No
Replace the Lift Pump.
10. PRESSURE LIMITING VALVE
1. Perform the no trouble code test "*PRESSURE LIMITING VALVE ON THE FUEL RAIL FOR INTERNAL LEAKS".(Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing)
Did the pressure limiting valve pass the test procedure?
Yes
Go To 11
No
Replace the Pressure Limiting Valve.
11. LEAKING FUEL INJECTORS OR HIGH PRESSURE CONNECTORS
1. Perform the no trouble test "*INJECTOR RETURN FLOW TEST". (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing)
Are any Injectors leaking or high pressure connectors leaking?
Yes
Replace or repair the leaking fuel injectors or high pressure connectors.
No
Go To 12
12. HIGH PRESSURE FUEL PUMP
1. Perform the no trouble code test "*HIGH PRESSURE FUEL PUMP PERFORMANCE TEST". (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing)
Did the fuel pump pass the high pressure fuel pump performance test?
Yes
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure). (Refer to 28 - DTC-Based Diagnostics/MODULE, Engine Control (ECM) - Standard Procedure)
No
Replace the High pressure fuel pump.
John
Before you post, ask yourself if this is going to add to the value of the thread?
04 F350 CCLB Cummins swap in progress
SOLD-08 Megacab longbed dually
SOLD-03 QC/LB 4x4 5sp
Originally Posted by Winkles View Post
The problem is that common sense isn't so common anymore...
JWH_03_Dodge is offline
post #10 of 31 (permalink) Old 10-23-2008, 12:32 PM Thread Starter
I changed the fuel filter and occasionally I am still getting a power loss. I was thinking of replacing the rail press relief valve next. Can the press relief valve cause an intermittent power loss? You would think it's either hooched or OK and not fail intermittently.
erikz is offline
post #11 of 31 (permalink) Old 10-23-2008, 01:12 PM
hmm... before you throw parts at it, let me look up the control line for the FCA, that way you can put power to it and check to see if it turns on/off.
John
post #12 of 31 (permalink) Old 10-23-2008, 03:19 PM
I took my truck in and the dealership told me they couldn't find anything, and of course it wouldn't do it for them when they took it for a drive. Got sick of it, and their bull service and sold the truck, now its someone else's problem. Sounds harsh, but so is towing a boat through the mountains with a truck load of friends and having it die on you, loosing power steering, and hoping like hell you can keep it on the road around the curve ahead. To hell with Dodge, bought a duramax.
Burgo is offline
