#2 (permalink) |
UTAH CHAPTER PRESIDENT
i had a caliper go out on mine. 1 pad was holding pressure still on 1 side of the drivers side disc. and the other pad on the outside of the disc wasn't even engaging... had to replace the caliper. and rotor,,, kinda $$$ but fixed the problem
2002 silver long bed, 6-speed,ADRENALINE, superchip, rv 275's, AIRDOG 150, boost elbow, dual silverline 4", with 6" tips, S&B intake.. http://www.cumminsforum.com/forum/utah/ thank you to http://www.hollandcourtsales.com/ |
#4 (permalink) |
is your truck pulling to either side? lets assume its pulling to the drivers side, have a buddy press the brake pedal while the truck is running and you should be able to see if both pads are pressing on the caliper or if one is stuck to the caliper. at least in theory.
94 f350 w/ 95 6bt, Nv4500, Valair clutch, 370 Hp Marine Injectors, #4 fuel plate, dodgezilla hybrid turbo, 18* of timing, lazer cuts, 4k GSK, 60lbs springs and a lot more! |
#6 (permalink) |
i hope not!!! whenever im at a redlight i can sometimes take my foot off the brake and the truck wont move for 45 seconds then it will jump....sometimes it doesnt do this at all.......runs fine long as im not stop and go....whats a transducer? thanks for your help
#9 (permalink) |
Tech Specialist
no just the trans pan - need 13mm(1/2") for the pan - 11mm(7/16") and 25 torx to remove the transducer - also suggest replacing the governor solenoid while you are there - 2 very common problems for these transmissions - good luck
