out of gas now won't start - Dodge Cummins Diesel Forum
Old 09-19-2008, 12:30 PM   #1 (permalink)
i ran out of gas last night. Put fuel in, primed system, started once with low rpm's only. now wont start at all. can anyone give me a hand.
1995 dodge 2500 cummins diesel
majorelectronics is offline   Reply With Quote
Old 09-19-2008, 12:32 PM   #2 (permalink)
What are you trying to start?
-2007- 5.9, 48RE, Leveled, 5" TBE, Amsoil CAI
DieselRookie is offline   Reply With Quote
Old 09-19-2008, 12:35 PM   #3 (permalink)
PatriotBlue12er's Avatar
got air in the lines.. what are you trying to start
2012 Dodge Ram 3500 Mega Cab Dually, 4x4, Auto, Black, Laramie, Black Leather
PatriotBlue12er is offline   Reply With Quote
Old 09-19-2008, 12:53 PM   #4 (permalink)
ynots57's Avatar
did you crack injector line to bleed off the air in system
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline   Reply With Quote
Old 09-19-2008, 12:56 PM   #5 (permalink)
sooter's Avatar
push the plunger on the lift pump about 100 times until you hear the overflow valve make a kind of squirting sound. then crack two or three injectors. crank the motor over until fuel start squirting out of the cracked injectors. tighten the injectors back up and crank it with your foot to the floor until she catches.
2004 Dodge Cummins 2500 qc 4x4, smarty tnt, homebrew built trans w/billet input, dpc triple disc converter, billet servos & strut assembly, transgo skift kit, red alto's, gm solenoid, etc, 2nd gen exhaust manifold, full 5in exhaust
sooter is offline   Reply With Quote
Old 09-19-2008, 12:56 PM   #6 (permalink)
Robertb6963's Avatar
How did you prime the system?
1997 Dodge 3500 CC DRW 4x4, 5 speed, flatbed, 6" long arm, 37"x12.50 Irocs, boost elbow, #11 plate, glowshift gauges, afc ff, bhaf, valair d/d
-SOLD- 2000 Dodge 3500 DRW Quad Cab 4x4 5 speed, 35x12.50 BFG M/T, cracked block
Robertb6963 is offline   Reply With Quote
Old 09-19-2008, 12:59 PM   #7 (permalink)
sooter's Avatar
i assumed he just primed it with the lift pump and it caught for a second then pushed more air to the injectors and quit..
Old 09-19-2008, 01:17 PM   #8 (permalink)
Blue01Cummins's Avatar
you are going to have to crack the injectors lines and crank on the truck till fuel shoots out. then tighting up... it might start with them cracked open then shut it off and start tighting them all back up..
2001 Dodge Ram 2500, 6 speed, Gauges pyro and boost, AirDog 150, 150 Horse fireball injectors, 4in exhaust..
Blue01Cummins is online now   Reply With Quote
Old 09-19-2008, 03:12 PM   #9 (permalink)
Nice call! Good info about the cracking the lines.
Wait a sec.....you put GAS in it? jk
Old 09-19-2008, 03:17 PM   #10 (permalink)
Tech Specialist
dodgentwo's Avatar
Yea. loosten 1,2, and 3 injectors about half turn, crank it till you spit fuel out, tighten them and then put the pedal to the floor and crank till she fires. Once its running, maybe crack the injectors open one at a time just to make sure there is no more air in the lines.
'05 White 6-spd Dually
'03 Blue 6-spd SRW 3500
And 3 '97 5-speeds
dodgentwo is offline   Reply With Quote
Old 09-19-2008, 04:46 PM   #11 (permalink)
sooter's Avatar
pour some gas into the intake and pump the throttle until the spark plugs fire it off. maybe choke it too.
Old 09-19-2008, 06:58 PM   #12 (permalink)
SmokinRamMike's Avatar
Try this if cracking the injectors is not working. Loosen the return line on your pump first, then bump the starter. When fuel starts coming out that is when you tighten the return line back up and start cracking the injectors. Good luck man running out of GAS is a SOB!
2001 2500 Cummins P-Pump for sale $13,000 OBO in FL. PM me for more info
SmokinRamMike is offline   Reply With Quote
