Old 08-25-2008, 04:14 PM   #1 (permalink)
Blowing coolant out reservoir. No coolant in oil.
I'm blowing coolant out of my '96 12v at the coolant reservoir at idle without truck even warming up. Loses coolant even when cranking without full start up. Not finding any coolant in the motor oil, nor is there any oil coming through into my coolant. Truck runs fine, does not seem to miss. Thought it was head gasket at first but now am not so sure. PLEASE HELP!!
jb138411 is offline   Reply With Quote
Old 08-26-2008, 09:21 AM   #2 (permalink)
renopker's Avatar
its a head gasket your blowing comp in to the coolent.
98 12v,2wd twins,3:55,g56 6speed,elec fan clutch,100 hp sticks, 10 plate FF aFC fB,3gsk Valair ats,fluid damper,60#springs,o6 exhaust brake,High Idle,prime loc, 4"exh,piller mount
renopker is offline   Reply With Quote
Old 08-26-2008, 09:48 AM   #3 (permalink)
clc
clc's Avatar
Sounds like the head gasket to me. I'd check the head for flatness and cracks while I had it off.
Fill out your signature so we will know more about your truck and any modifications. That will help us help you in the future.
96 3500 4WD, 47RE, gauges; 97 3500 4WD 47RE, gauges; 97 3500 2WD 5-spd; all club cab. 98.5 2500 2WD SB, 5-spd, gauges, quad cab
clc is offline   Reply With Quote
Old 08-26-2008, 01:57 PM   #4 (permalink)
DORKWEED's Avatar
Location: "The Peoples Republic of Illinois".....behind enemy lines
with the above posts!!
NRA LIFE MEMBER
DORKWEED is offline   Reply With Quote
Old 08-27-2008, 04:41 PM   #5 (permalink)
Thank y'all very much. The help is appreciated.
Old 08-27-2008, 05:06 PM   #6 (permalink)
my '97 did that after the jokers at the dealer replaced the short block and left the radiator cap loose. I didn't think to check for that, or the vacuum lines left disconnected, and drove it for a couple weeks in the summer, towing and everything. Luckly, the 5.9 is a tough motor, and does not overheat easily, even when the coolant system is not pressurized. The cap was partway on, so it would build a little pressure, but let the coolant out to the reservoir bottle, and then leak air when it cooled, instead of pulling the coolant back in the motor. After a few cycles, the reservoir was full and the top of the radiator core was visible. I just put the fluid levels back to the right places and made sure the cap was back on right, and never had it happen again. you might have a bad cap or an air leak on the hose to the reservoir.
New: 2008 black MegaCab, 6.7, 4x4, auto, stnd gears, no mods, only 9k miles so far
Old: 1997 extended 5.9, 4x4, 5sp, 150k miles, mostly stock but added edelbrock shocks
bart9505 is offline   Reply With Quote
Old 08-27-2008, 06:51 PM   #7 (permalink)
Do a pressure check on the cooling system- but it sounds like a head gasket- other then popular misconception - 9 time out of ten- coolant doesnt make it to the oil when compression gasses over pressurizes the water syatem- lifts the cap- and blows coolant out into the overflow tank until final loss of water causes a sparatic overheat on your gauge.
2001 extended cab, full bed 2500 4x4 superchiped, 160,000 miles , Running home brewed bio for 7 months- Hauling butt, smelling like french fries- Navy Cummins tech for 15 years
arcoen is offline   Reply With Quote
Old 08-30-2008, 11:07 PM   #8 (permalink)
totalloser's Avatar
+1, but I would try a new radiator cap first. If it is really bad, the water pump could push coolant out. If it isn't losing much at low temp, this could be the problem, and is cheap and easy to try. So is a pressure check. Look for a crack in the radiator neck, too. I would do these first JUST IN CASE.
01 24v 100hp tips, 4"ss BDbrake &steering brace PSCpump 1.5"dom steering tapped box 1.5"ram manual CAD switch dual carters 3.55's LSD, big shaft nv5600/241HD 6 35's inners pulled in (no spacer) Ugly black and thrashed!
totalloser is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
