Old 08-24-2008, 12:30 PM   #1 (permalink)
Boo
Need Quick help!
Driving down the road 60 mph , truck just stops, thought I ran out of fuel , gauge shows 1/4 tank. Had a friend bring me 5 gallons. fuel filter canister is full, will not start. I hear the fuel pump come on after trying to start it but no start????????
2000 Quadcab 4x4 White, Automatic tranny.
Boo is offline   Reply With Quote
Old 08-24-2008, 12:34 PM   #2 (permalink)
Cummins CrAzY
DevilDogDiesel's Avatar
Any codes?
2000 2500 ext. cab short bed, AFE cold air intake, single 6 inch stack, high tech turbo, FASS 95, Scheid injectors, Adrenaline, HP intercooler boots, fully built trans., custom trac. bars, HAISLEY MACHINE ALL THE WAY!!
DevilDogDiesel is offline   Reply With Quote
Old 08-24-2008, 12:34 PM   #3 (permalink)
Super Administrator
BBRam's Avatar
Have you replaced the Fuel Filter?
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph)
Old 08-24-2008, 12:34 PM   #4 (permalink)
It's not uncommon for the fuel sender to quit working and to run out of fuel on these trucks. This said, if you have fuel to the lift pump this may not be the case. If you have any tools you should disconnect the fuel line at the injection pump to make sure fuel is getting there. With a 19mm wrench you then need to crack the injector lines loose at the head to make sure the injection pump is delivering fuel. Also try swapping the fuel pump relay with the horn relay to see if that helps (they are the same), sometimes the relay just takes a dump.
You should post this in the 911 section for better exposure.
mishkaya
'01 6spd, Mach 6's, Helix 2 cam & springs, twins, Adrenaline, DD clutch, DOR bumper, etc...
mishkaya is offline   Reply With Quote
Old 08-24-2008, 12:36 PM   #5 (permalink)
Super Administrator
BBRam's Avatar
mishkaya
I moved this thread to the 911 forum.
Old 08-24-2008, 12:58 PM   #6 (permalink)
Boo
No codes, just stopped running, I do hear the pump running when I turn the key on and off.
Filter is almost new!!!!
Old 08-24-2008, 01:11 PM   #7 (permalink)
If you are still running the stock lift pump, just because it is running does not mean a thing, you need to check the inlet to the injection pump to make sure it is delivering fuel.
mishkaya
Old 08-24-2008, 01:14 PM   #8 (permalink)
Boo
truck is bone stock 78000 on it, where do I check the fuel at, thanks
Old 08-24-2008, 01:16 PM   #9 (permalink)
Boo
Do I break the line loose as it comes into the IP. Whats making the noose the lift pump?????
Old 08-24-2008, 01:20 PM   #10 (permalink)
Yes, first test is to break the line loose as it enters the IP ( you can just follow the line from the filter to the pump), it's the one on the right hand side. Then bump the starter briefly and check to see if fuel is coming out of the line. The lift pump should only run about 30 seconds. If you have fuel there, you will then need to crack an injector line or two at the head and crank the engine to see if you have fuel there.
mishkaya
Old 08-25-2008, 12:24 PM   #11 (permalink)
mrclean's Avatar
The noise is the pump running......but often the impeller comes loose on the shaft. The pump runs, but doesn't pump any fuel. HTH
mrclean is offline   Reply With Quote
Old 08-25-2008, 02:36 PM   #12 (permalink)
Boo
Well after spending time on the phone with mishkaya who is a hell of a nice guy to take time out of his day to talk to me, I find that the lift pump is pumping and after breaking the fitting loose at the injectors, the VP looks like it is getting fuel, but still no start, I'm lost now. I ordered a pressure gauge from Gino's looks like I need one anyway
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
