Old 08-22-2008, 07:48 PM   #1 (permalink)
2002 6spd 70,000 mile all stock.Help... Please!
I just came across this website after trying to google my problem. My truck just started acting funny on the way home tonight. When driving thru town at a steady pace, and starting to accelerate it will not respond to added throttle, then 10-15 seconds later it hits (like turning on a light switch)? It happened several times on the way home, but if I did drop a gear it would raise the rpm's and it would take right off. I'm no mechanic, and need any help you can give. I have no check engine lights or so on. Thanks
WV02Dodge is offline   Reply With Quote
Old 08-22-2008, 07:49 PM   #2 (permalink)
Cummins Diesel ADdict
dom42's Avatar
im gonna say it's a fuel issue. but not an expert at it.............
im sure some1 will chime in on this issue.
good luck
2006 2500 QCLB 4x4 auto-5" SilverLine TBE - cfm plus- s&b CAI system- 6 inch superlift- kore components- 325/60/20 bfg AT's- 20" motometal- fs2500 on engine & tranny- maghytec all around- 4.10gears- edge juiced/w attitude- truckcoverusa roll out cover- rhino linings- firestone bags- Nfab 6step
k7gsxr1000- full race bike- ohlins all around-brembo masters-full ti arata exh-pretty much everything
dom42 is offline   Reply With Quote
Old 08-22-2008, 07:51 PM   #3 (permalink)
tramp_line_ape's Avatar
possibly the vp-44... maybe a 2nd gen guy will chime in.
07 6.7 cummins, 6 speed, one-ton, electric blue, gauges, afe intake, MP-8/Superchip, 4" BADP TB, egr delete, edge w/attitude
Give him books and give him books, and all he does is eat the pages
I.B.E.W. local 57 America is Union
tramp_line_ape is offline   Reply With Quote
Old 08-22-2008, 07:51 PM   #4 (permalink)
Tech Specialist/Super Moderator
TrueValue Truck's Avatar
There is some good information in this thread....sounds like the same issue your having...hope it helps....
Occasional dead pedal
Caldwellfire.com
06 3500 SRW MC ,Smarty REVO,X2 Race stack, Commander,CFM, Monster Air COI,AFE Torque tube,FASS 150 HPFP LP,Muffler delete,Tipple disc Converter and VB ,ProComp 2" leveling kit,Timbren's,Reese Class V Tow Beast
Ohio Coal Rollers
Cumminsforum.com
TrueValue Truck is offline   Reply With Quote
Old 08-22-2008, 07:54 PM   #5 (permalink)
Steveo24's Avatar
Definately sounds like the dead pedal syndrome. Try the APPS sensor reset.
98.5 3500 2WD dually 4:10's lAuto Meter fuel, boost, pyro, and trans temp lOne piece headlights+ LED's l5 inch mitre stacks lHX 40 l150 horse Coaltrain sticks l.093 tubes l Smarty lEdge Comp HOT lStage 2 snow kit lBHAF lBD pusher pump lAmsoil, engine+diff
Steveo24 is offline   Reply With Quote
Old 08-22-2008, 08:07 PM   #6 (permalink)
I'll try that 1st thing in the morning. Bad thing is, I was suppose to take my boys outa town tomorrow. I'll let you know if it works and keep checking on any other info "IF" I still need it (Hope unplugging cables and resetting things will do it!). And, thanks for all the fast replies.
Old 08-23-2008, 09:34 AM   #7 (permalink)
So far so good. It does show a p1693 code?
Old 08-23-2008, 09:43 AM   #8 (permalink)
P1693 DTC Detected in Companion JTEC Mod
not sure what that means, maybe someone with a little more knowledge than me does...
Old 08-23-2008, 09:44 AM   #9 (permalink)
Diesel Tech
dkletti8's Avatar
I had the same problem with my 02. Luckily it was under warrenty yet. I was pretty sure it was the vp44 injection pump. My dealer started with the lift pump, I went to pick it up and it acted up right away so they ended up replacing the vp44. No problems in the last 2 years.
02 2500 4x4 5.9HO 6 speed 4"mbrp straight pipe Diablosport Powerpuck BHAF silencer ring mia moon visor sprayed liner
52 Power Wagon all stock
dkletti8 is offline   Reply With Quote
Old 08-23-2008, 09:50 AM   #10 (permalink)
if you've only got 70k, the motor is still under warranty.... so that would cover lift pump, injection pump.... right?
Old 08-23-2008, 10:22 AM   #11 (permalink)
Sorry, I was wrong on the mileage..it is at 80,000. I keep getting extended service plans sent in the mail..guess i should have jumped on it. I'm taking it out for a drive in a few and hope its still fine. If not, where is the best/cheapest place to buy a vp44? What kind of $ are we talking....
Old 08-23-2008, 02:37 PM   #12 (permalink)
totalloser's Avatar
There are two options that are noteworthy; One is the hot rod vp which gives you an extra 100 hp or so. Performs just like doing 100 hp sticks, I think. The other thing to consider is that the heat cycles somehow cause a problem with the solder to the circuit board in the vp. Something about the solder crystallizing and losing a good contact. Apparently UPS got special ones built using some other kind of solder to deal with this problem. Most rebuilders just test them, they don't fix this. I can't remember the builder that addresses this issue, but it might be worth considering.
The other thing that goes out is a sleeve and pin hogs out when the lp pressure is too low for too long. I think all the rebuilders replace these parts, but the company that does the solder upgrade replaces the aluminum parts with heat treated steel. If I can find the flier I printed, I'll post the manufacturer. My problem when I was looking at this turned out to be lift pump pressure too high (16 psi).
I think the rebuilds range from $1200 to $2500 or so. I am sure there are folks on here with better info, though.
01 24v 100hp tips, 4"ss BDbrake &steering brace PSCpump 1.5"dom steering tapped box 1.5"ram manual CAD switch dual carters 3.55's LSD, big shaft nv5600/241HD 6 35's inners pulled in (no spacer) Ugly black and thrashed!
totalloser is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
