Old 08-18-2008, 01:26 PM   #1 (permalink)
No fuel to injectors
I own a 2001 Cummins. I had the injector pump replaced about two years ago (50K miles) with a rebuilt one and a low fuel pressure sensor installed as well. About a year ago I found that if the engine was off more than about 5 hours the engine would not start unless I first bumped the motor and let the lift pump run for about 10 seconds. Once I did this the engine would start fine. It did not matter if it was hot or cold out. It would not start if I did not do this.
The other day I noticed that the low fuel pressure wire was not connected to the sensor. Upon reconnection the light would come on when the accelerator pedal was more than halfway engaged, not good. I replaced the fuel filter which was not the cause. I replaced the lift pump and now I can not get the engine restarted.
I loosened the banjo bolt feeding into the injector pump and fuel is being delivered there. I loosened two injectors on the head and can see no signs of fuel. I loosened two lines exiting the injector pump and can see some signs of air and fuel. Its hard to see myself because I can only see that area after the engine stops rotating.
I have bumped and rotated this motor over to point I think I am going to run the batteries out (25+). Do I need to bleed something I am not aware of? Has my injector pump died? Appreciate any help, I really need to get my work truck running again.
baileymike is offline   Reply With Quote
Old 08-18-2008, 01:32 PM   #2 (permalink)
Dad
Administrator
Dad's Avatar
Sounds like a VP failure, but it seems odd that it would quit when you changed the LP.
Might try loosening about 4 injectors at the head and cranking it over to see if it will push the air out.
Have you got any codes?
High Rider: 98.5 Ram 2500 4x4, 5 Spd, SB 13", A3000 turbo, DDP Stage 3 sticks, studded, 4" TB,, AEM Intake, Gauges, FASS95, S-Chips Tune
Low Rider: '06 Chevy 1/2 Ton, Victory Red, 2/4 Drop, roll pan, sport mirrors, rollin on 20's
Dad is offline   Reply With Quote
Old 08-18-2008, 03:11 PM   #3 (permalink)
I do not have a code reader. Tried loosening 3 injectors but did not see any fuel comming out.
Old 08-18-2008, 03:21 PM   #4 (permalink)
MOPAR MAN's Avatar
You should still be able to check to see if there is any codes buy doing the key trick. From the off position turn to the on position back and forth 3 times than leav in the on position. It will desplay any codes in the odomiter screen. Good luck with getting your truck running.
00 Ram 2500 4x4 5-SPD, AirForce One Performance CAI & Intake horn, 5" TB Exhaust, Edge Juce W/Atitude (HOT), Custom GT3788R Dual B.B. turbo, 120HP EDM Injectors, FASS 150/150, H.O. VP44, 7" Lift, ValAir DD Clutch, Fluidamper, & more to come
MOPAR MAN is offline   Reply With Quote
Old 08-19-2008, 09:41 AM   #5 (permalink)
First code is 1693
Then ECU codes are
0522
0230
0216
Whats does all this mean?
Tried lossening injectors and still get no fuel. Thanks for any help
Old 08-19-2008, 09:48 AM   #6 (permalink)
Farmboy's Diesel
farmboysdiesel's Avatar
It's time for a new VP.
Farmboy's Diesel Performance
FBD BUDGET EXHAUST
Products By: FBD, AirDog, Blue Chip, DDP, Smarty, TS, MaxSpool, HaloMax Springs, Grand Rock, Fluidampr, AFE, Edge, TST, MBRP, Industrial Injection, ARP, Auto Meter and More
704-290-2289
1999 Dodge 2500 4x4 II 66/FBD2 TWINS, 7in Stack, HTS/FBD Tranny, DDP Inj's, FBD Trik 3VP, HaloMax Springs, MaxSpool, NX SD2, Fluidampr, DragTST
Check out www.farmboysdiesel.com
farmboysdiesel is offline   Reply With Quote
Old 08-19-2008, 09:54 AM   #7 (permalink)
Dad
Administrator
Dad's Avatar
The 0216 is not good. Indicates the VP44 is wearing out mechanically and at some point was unable to advance timing. On top of the symptom of not having any fuel at the lines, I'd say the rotor in the VP44 seized.
0230 is a lift pump code. Not surprising since you just replaced it.
0522 is an oil pressure sensor code. Probably just a transient code.
Old 08-20-2008, 12:08 AM   #8 (permalink)
Any recomendations on a reliable rebuilt source. Seems my last on only went 50K miles?
Old 08-21-2008, 02:53 PM   #9 (permalink)
Meierznutz's Avatar
I hate to say, but if you were running a while with low fuel pressure the damage was already being done. Changing the lift pump and trying to start the truck to prime caused the VP to fail. When I prime, I only bump the key and then wait until I hear the pump stop before turning off and then bumping again. If you crank the engine then you are turning the VP while it is dry and that will burn out the rotor. I would suggest an Air Dog or FASS pump after you do the VP. They should get the VP to last longer (btw, I'm on my 3rd LP in 102k miles) Depending on the price and what you have for mods, the Hot-Rod VP-44 is an option.
'02 2500 QC SB 6 Sp, Con-OFE, Banks Brake and Monster Exhaust, JL Stealth Sub, AM Lunar gauges, Air Dog Raptor, Home built Hybrid 35/40 pushing 33psi!
Is there a Mega Cab in my future??? P.S. This truck for sale.
Meierznutz is offline   Reply With Quote
Old 08-21-2008, 03:04 PM   #10 (permalink)
got smoked's Avatar
Industrial injection has a deal vp44 fass 150 for 1700. website go to hot deals www.idustrialinjection.com
2000 black sport 4 in lift nv5600 stock but not for long!
got smoked is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
